Getting rid of the tri-flange?
Old Oct 13, 2014 | 05:26 PM
Rick1991's Avatar
Default Getting rid of the tri-flange?
So I picked up a CTSV T56 today, special ordered with the tri-flange setup. I would like to insall this tranny in my 1991 Silverado which doesn't have the tri flange setup. What is the best way to go about changing it/adapting it?
How it looks..
How I want it to be...
Any help is appreciated.
Old Oct 13, 2014 | 07:15 PM
jmd's Avatar
jmd
Search 1000hp t56 ssr ls1tech.com
And read the pdf in that thread.
If the shifter location is good for you, keeping it as-is might be a good option.
Old Oct 13, 2014 | 07:51 PM
Rick1991's Avatar
The shifter location is perfect, its exactly what I needed. But I'm not sure if I'm confused, or your confused but I need to figure out how to hook up to my driveshaft that I have now using the triple flange.
Whether someone knows where to purchase an adapter maybe even?
Old Oct 19, 2014 | 03:41 AM
branndonw's Avatar
Driveshaftshop.com can make you a driveshaft that will work with the flange so that you don't have to convert the trans to a slip yoke. They do away with the U-Joint and slip yoke and use a CV that bolts up to the flange with an adapter. The CV allows the driveshaft to move in and out with rear axle travel. It will use a U-joint to connect to rear end.
Old Oct 25, 2014 | 12:40 PM
Project GatTagO's Avatar
A CV driveshaft won't have the travel that he will need in a truck.
Andrew
Old Dec 23, 2014 | 05:48 PM
Rick1991's Avatar
This is what I ended up doing, its a 1330 U-Joint, anyone know how strong they are? Still need to measure out what driveshaft length I need.
Old Dec 24, 2014 | 05:33 PM
showdog75's Avatar
Where did you find that? I've got the same trans facing the same issue. Thanks
Old Dec 24, 2014 | 06:32 PM
Rick1991's Avatar
I took it to a local transmission shop and they had the ujoint. Its supposingly off a ford.
Old Dec 25, 2014 | 07:54 AM
showdog75's Avatar
I just wonder since it's fixed in place how well it'll hold up. Seems like there should be some give line a slip joint setup.
Old Dec 25, 2014 | 04:06 PM
Rick1991's Avatar
I haven't even started the swap yet so I couldn't tell you. The driveshaft will have some give in it when I get it made.
Old Dec 27, 2014 | 10:44 AM
AMP-D's Avatar
Make sure the yoke fits properly against the output shaft seal. I know a guy who burned up a perfectly good 5th ten Camaro unit trying to do the same thing as you are. He put a yoke on there that didn't fit the seal properly and it leaked all the oil out and burned it up.
Old Dec 30, 2014 | 11:14 AM
Rick1991's Avatar
Wow thanks for the warning, I would be beside myself if that happened. Alberta driveline is working with my so I'm trusting the "professionals" know what they're doing.
Old Mar 5, 2025 | 09:21 PM
SinghOnBoost's Avatar
I was looking online for the same thing, unfortunately the guy who sold me the tr6060 was dumb enough to cut the centre support pin (it helps to align the aftermarket adapters). So, if u can help me with this, that would be really appreciated. im doing 2008 Mustang 5.3 turbo Ls swap with the tr6060 ofc, and yeah im from Alberta too (Calgary). I need to know what transmission did that yoke came off, and how is it holding up??
