Mityvac question
if you disconnect it and there is a bubble still in the system that has not reached the Mighty Vac then yes the suction from the MC/Slave when released causes loss of vacuum which would pull the bubble back.
I find using low PSI, around 5-6, works better as to much will suck fluid out also
