keep my monster 11inch or go rxt???
so ive been starting my build thread and curious as to what i should do. i currently have a monster ceramic 11inch with 18lb flywheel with only 600 miles on it. should i keep it? didnt have any problem with it loved the clutch. or should i go with the rxt?? the car is going to be drag raced id say 10 times a year and go to roll race/half mile events occasionally. other than that the car only goes to local car meets. the car is a 00 camaro with a 403 and f1a. max boost is 18lbs but 12lbs on the street most of the time. or should i keep the monster and put the money elsewhere?
However if you want to upgrade, give us a shout and we can get you a good deal on one of our street twins.
Based on what you're saying about the current Monster setup, I don't see any reason why to change it. If you're unhappy, make a change. If not, don't. Oftentimes people make a change when they are happy and come to find out the grass isn't always greener on the other side.
Originally Posted by SNLPerformance
Yes, the only difference in the 11" units is the disc. The Iron is not recommend for daily driving, as it is very aggressive.
