Flywheel Dimensions ???
Your best bet might be to get the 99-00 long crank flywheel/clutch combo. Check for starter engagement, then try to find a compatible 26 spline disk.
Let's not pass along steaming piles that will be repeated.
I did run across this at Novaks site a while back indicating long crank 4.8 flywheels, but again, I've never seen one. Not holding my breath either.
https://www.novak-adapt.com/knowledge/gm-crank-spacing
