LuK 04-905 Clutch Set
if the shoulder of the bolt is going flush when tightened, I don't see why it matters unless the bolt is smaller diameter than the hole.
yup, but if you aren't sure, just look at the bolt and see if it's flush. if it's flush, you good. i run the ARP only because i had a set laying around
