Magnum F require shorter driveshaft?
My t56 had no internal stop inside it, so I could slide my driveshaft into my trans until I bottomed against the seal, and then get my rear u-joint to go in. My MagnumF has an internal stop in it, so I can’t slide my driveshaft into the trans nearly as far, adding to this issue. If it weren’t for this internal stop, I think I could have made my driveshaft work without having to cut any more length than the new larger front yoke would have required.
Same here, but my driveshaft guy took care of this when installing my new front yoke. I think I went 7/8” shorter...1350 yoke is larger, which is reason for needing shorter driveshaft, in case others reading are wondering why this is.
The following users liked this post:
Xeno7 (01-26-2023)
Reviving this thread because there is a special Sonnax yoke for the Magnum F, part #T3-3- 2491S .
Its 0.97 inches shorter than the Sonnax 3-3-2491HP
I was tearing my hair out trying to figure out why my stuff didn't fit right .....and I stumbled across it.
The following 3 users liked this post by Zanie:
Good to know sir. I simply used the yoke that came with my f-body magnum. I bet it was the wrong one.
Bumping this old thread up again lol. Got my magnum f installed and using the sonnax yoke for the magnum f and it only goes about 2inches into the transmission, this does not seem right. Called tremec and they said it should go all th way in. Anyone have any suggestions? I'll be checking the splines on the yoke for burrs.
I'll chime in because I just finished my Magnum F swap recently.
I had no issues putting my stock driveshaft back in. Of course, I had to swap the slip yoke and u-joint that I bought from Tick Performance
The yoke is a Sonar T3-3-2491HP and the u-joint was an SKF UJ447. Had everything balanced and it's been performing flawlessly.
Do you have the right slip yoke?
Was using sonnax: T3-3-2491S
What is everyone running for rear ends with this trans? I have Strange S60 with Mag F trans… everything bolted up EXCEPT the shaft! It’s about an 1” too long! Doesn’t go into rear yoke. I did just as all adjustable rear arms, panted and short to arm… wondering IF the suspension has affected DS length?
Hiya. So, with this Magnum-F specific Sonnax yoke, does that effectively fix the length issue so the same driveshaft can be used? It sure sounds like it.
