Need 6-speed shifter - mine is Worn Out
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
I have a 1998 Pontiac Firebird Formula and the 20 year old Pro 5.0 shifter for my T-56 transmission is worn out!
What do you recommend? Brand, model, where to buy, etc.
Summit has a Hurst Billlit/Plus model 3915061 for $310.
I like Hurst shifters but I would prefer to spend a little less.
Suggestions?
Suggestions?
Thank you for sharing your experience with the Billet Plus. I really liked the Hurst shifter that came with my 1966 Olds 442. Far superior to the shifter on the GTO's.
I had no idea that springs could be replaced on any shifter. That's good news! I wonder if the springs on my Pro 5.0 can be swapped. I don't remember who made that shifter but I'm going to do a search and see if I can find out and contact the manufacturer.
Thanks for offering a stock shifter. I'm not interested in the stock shifter that came on F-bodies. Shifts were not crisp like many of the after market shifters. The only thing I did like about the stock shifter was that there was less drive train noise.
Save the manuals!
The factory-option Hurst is very similar to the Billet Plus, but has a separate base plate instead of an all-in-one billet body. Here's what it looks like next to the stock shifter: https://ls1tech.com/forums/manual-tr...ml#post4295370
If you can get this factory-option Hurst with the Hurst shifter handle it came with - go for it. That handle is great. (I added it to my Billet Plus, but they are near impossible to come by, now.)
I assume the factory-option Hurst and Billet Plus feel similarly. The things you will notice most are the shorter stick and the superb Hurst shifter handle/ball. (If you can get it. The shifter pictured in the thread above does not have the special Hurst handle/ball depicted.)
Save the manuals!
BTW - Here are the replacement springs for the Billet Plus: https://www.holley.com/products/driv.../parts/2305000
One of the other nice things about the Billet Plus is that one can adjust the feel of the shifter by removing one of the springs. (There is an inner and an outer spring.) So, there is some adjustability to it.
Yesterday, I ordered a Billet Plus shifter from JEGS. It is scheduled to arrive on Monday! I've downloaded and printed the instruction manual and I'm excited about having a new shifter. I like the way the spring tension can be adjusted and that replacement springs can be installed if necessary in the future. 20 years ago when I bought the Pro 5.0 shifter, there were adjustable stops for forward and backward movement. The instructions said the position of the stops was important to avoid damage to the transmission. Thank goodness there are no stops on the Billet Plus to be worried about.
Save the manuals!
Looking at the other Billet Plus models, the T56 instructions for the C6 say that the stops are "optional" because the transmission has internal stops built into the unit. The Ford transmissions require that the stops be adjusted. I'm not sure what our deal is. Maybe we have internal stops in the transmission???
My Billet Plus shifter was delivered by FedEx yesterday. You are absolutely right about the shifter having adjustable stops and that the stop adjustment is Not mentioned in the installation instructions. I don't know if my T56 has internal stops but I am not willing to take a chance so I called JEGS tech support. After ~25 minute wait I talked to Larry. He was able to find instructions on how to adjust the stops to avoid possible transmission damage. I saved the instructions in a MS Word document and will include them in this reply in case others want/need them. Adjust stops on Billet Plus shifter. (Probably the same technique for all shifters)
Partially back out stop bolt. Leave a few threads showing
Firmly push 3rd gear forward and hold
Screw in stop bolt until it makes contact, then release stick to neutral position
Back out bolt One Turn then tighten the jam nut
Repeat for 4th gear.
Save the manuals!
Suggestions?
Suggestions?
