How do I know I have a Hurst Shifter?
Sorry for the noob question. I have a 02 WS6 and read that not all WS6 comes with a hurst shifter. Is there a RPO code or something that tells me if I have a regular shifter or the HURST?
i say buy a short shift handle first. its a good cheap mod. When ur about to install ur shifthandle check out ur shifter. Heres a pic of a stock hurst next to a standard shifter. The stock hurst has a thicker base while the standard look flismy. If its not a hurst then buy a pro 5.0 or in my case find soembody who is selling a stock hurst.
Originally Posted by orangeapeel
that is a bad way. You can check with the codes on the driver door.
I put a Hurst from an SS in my Z. It's a lot different from the stock Z shifter. But there is a lot more vibration especially in 3rd and 4th gear. Don't know if it's normal but i'm thinking of going with a Pro 5.0 in the near future.
