Lenco or Liberty
* New T-56 with G-Force gear kit already installed (Camaro, Cobra, and Viper Style) $4695.00
Matt
Matt
I have a lakewood specialty bellhousing with a cross shaft style clutch, the only thing LS1 left is the Flywheel. The cluch is a ram single disk slipper unit that is fully adjustable. As far as life on the cluch my friend has 100 passes on his and just gets it gone through at the end of the season. Enlighten me on what PITA factor is.
Matt
I'll put the pics up as soon as the cutting begins. Just got the transmission yesterday and I think it might be a little tough to hide that one, but hopefully it can be pretty well hidden because I dont want it to look like ****. Gimmy a few weeks the car will be up and running and should hit APE's dyno shortly after. The transmission has zero power loss going through it so i'm hoping for some good numbers on the dyno and good track times. Hopefully all the work and cash is worth it. It should be a fun trip down the track no matter what.
Matt
What setup mods did you have to do to allow for the trans input length for the Gen III block, and what release setup are you using for the crossshaft?
thanks for the reply in advance. Thanks for pioneering things.
-Matthew
As far as set up mods Libertys will make the input shaft of the trans at any length you want, so all you have to do is buy a Lakewood Bellhousing for a small block chevy and a Libertys, measure where the pilot bearing lands in reference to the back of the block and add bellhousing depth. I have a 8 1/8" deep bellhousing. After that you give Libertys the specs on the car and they build the trans accordingly. Should be an adventure.
Matt
Seriously, how did it work out? Where are the pix?
It's worked out great so far. The car has gone 9.27 @ 147.2 on motor and we have made 18 passes in the 9's so far and we have made not one clutch adjustment as of yet. Am I happy, hell yeah we set the LS1 NA record and now we are shooting for 8's NA next year. I love my trans and would never change it...
Matt
