Help w/ Squeeling Sound
Old Jul 30, 2004 | 11:51 PM
convexion's Avatar
Question Help w/ Squeeling Sound
Hello all. I'm having a very strange problem that I can't seem to find an answer for anywhere else on the forum. When I press in the clutch pedal I'm getting a very muffled shrill squeeling noise. At first I though it might be a belt, but it sounds more like it's coming from the transmission.
Does this mean I'm going to need a new clutch? If so, I've already decided to go with the Spec 3 with the billet flywheel. But my other question is should I get a new master cylinder for my '02 Z28 as well?
Old Jul 31, 2004 | 12:59 PM
convexion's Avatar
No one?
Old Jul 31, 2004 | 03:44 PM
chpmnsws6's Avatar
throw out bearing
chpmnsws6's Avatar
BTW- go with the stage 4. its just as streetable but less headaches
Old Jul 31, 2004 | 03:49 PM
TeamZ's Avatar
i had something similar to that.. the bearings in the rear end were shot..
Old Jul 31, 2004 | 04:29 PM
convexion's Avatar
Thanks for the replies. Is there a guide to replacing these bearings?
Old Aug 1, 2004 | 12:37 AM
convexion's Avatar
Is it relatively easy to replace the bearings or will I have to take it for repairs? I'm pretty new to this so please bear with me. It's my birthday, so be kind.
Old Aug 31, 2004 | 07:24 PM
flyingguy001's Avatar
So did anybody respond on what to do to change the throwout bearing? Cause my 99 SS is makin the same screaching noise right as i let out on the clutch, and sometimes it makes a small grinding noise. I figured it was the bearing, but how do you replace it? It is a repair that requires lots of tools and time? Thanks ahead of time
Old Aug 31, 2004 | 07:50 PM
DaddySS's Avatar
Throw out or pilot bearing, either way the transmission has to come out. Replace the clutch, flywheel, slave, throw out and pilot bearing. It's a fairly big job and requires a good set of tools.
Old Sep 1, 2004 | 12:19 PM
Inspector12's Avatar
TT-TECH Veteran
I am in Houston Texas if any one is near just give me a call I can help you out. It could be the thowout bearing or the pilot bearing I've seen both make that kind of noise. Could be a number of things you just wont know untill you pull it and take a look. If you have any doughts about your mechanical skills take it to a qualified mechanice that you trust! If you don't know one ask people on the board who they have used in your area etc...
