MityVac
Old Aug 19, 2004 | 12:28 PM
1SloMoFo's Avatar
Default MityVac
Alright i have read and read and read but i still cant figure out how to use the mityvac to bleed the hydrolic clutch system so easily please help
Old Aug 19, 2004 | 04:37 PM
demonspeed's Avatar
It's not mine! woo hoo!
I was in the same boat. I tried it and got more air in the system than I had in the first place. Get 2 other friends, one to open the slave bleeder valve, one to watch the fill on the master, and yourself to pump the clutch in the car. It'll be done in no time and saves $40 bucks.
Old Aug 19, 2004 | 08:19 PM
5 Liter Eater's Avatar
Put the mitivac together with the container in line. Stick the pencil tip attachment into the bottom of the CMC reservior so it seals against it. Start pulling vacuum up to ~20"#. If the fluid level in the CMC drops you don't have a good seal. Some fluid will drain into the container along with some bubbles. Pump the clutch to get more air out. When done slowly release the vacuum and top off the reservior.
this is the quick and dirty explaination.
Old Aug 22, 2004 | 04:06 PM
Krab's Avatar
Don't forget to have some brake fluid in the line of the mityvac so you won't bring more air bubbles into the system.
Old Aug 23, 2004 | 07:20 PM
1SloMoFo's Avatar
I set up the mityvac as you said and bubbles just kept comming out Do you think that there is a broken seal letting air in the line somewhere?
Old Aug 23, 2004 | 07:45 PM
Krab's Avatar
Are they very large bubbles coming out pretty fast, or smaller ones that are pretty seperated?
Old Aug 24, 2004 | 09:49 AM
Dal1as's Avatar
You're likely pulling air through the plunger in your master. I did the same and replaced it. Still have hydraulic issues but think it's my slave.
Old Aug 24, 2004 | 05:24 PM
1SloMoFo's Avatar
well with 20 on the gauge they are big sometimes and some times they are small but mostly big and they are like spaced apart just about the same
Old Aug 24, 2004 | 05:25 PM
1SloMoFo's Avatar
should air be able to pass through the plunger like that i thought that it would have to be sealed so that no air is to get into the system i just replaced the slave cylinder this past weekend so there is no way it could be that at least i hope
Old Aug 25, 2004 | 02:22 PM
Dal1as's Avatar
I mean the plunger in the Master and no air should not pass through. When my master was bad I could pull constant air. Replaced it, and can pull no air at all. In fact if I pump the pedal it will get pulled to the floor from the vacuum. lol
Still having hydraulic issues though. Just gravity bled the system and am waiting a few days to see how it works out. Maybe my slave is bad.
