shifting w/o clutch
You may be very good at rev matching and get the box to last but you will never match consistently enough to save serious wear on your synchros. Save a clutch/ trash a trans. Does not sound like a good way to go to me.
Actually, shifting against a clutch even if its only partially driving & unmatched is always going to cause more wear than disengaging the clutch. Do what you like, but trans shops love the rev-match work.
WTF are you talking about.Why would you try to shift with no clutch.Power shifting-holding that gas pedal to the floor and never lifting off during a speed shift to the next gear- that should good enough for you.Unless you want to buying a new tranny.The fact that you are a little unsure tells me that you should NOT even think about shifting with no clutch.
There is a diffence between POWER shitfting (Foot to floor, SLAM into gear). Once in a while I REV match my shifts.....if done properly the stick will fall right into place and then you continue with you excelleration.....It like shifting with the clutch, only no clutch. Go through the same motions, just not engaging or disengaging the clutch......
Fine for regular driving (assuming youre good at clutchless shifting) but bad for racing. The idea is to let the engine rpms naturally fall down to a point where theyre matched with the rotation of the wheels in the next gear (upshift rev-matching). You can try it yourself: I think its easiest from 3 to 4. If you take 3rd gear up to 2500 rpm or so, gently let off the gas while applying light pressure to the shifter, as you let off the gas the shifter will release the stick into neutral. Now as the rpms slowly fall (foot still rolling off the gas ever so lightly) apply pressure to the stick towards fourth gear. As the engine rpms drop past 1900 rpm, fourth gear should "accept" the stick and it will easily go into gear without much effort. It takes a while to develop a feel for the right ammount of pressure. Too much and you force it into gear before its ready. Too little pressure and when the rpms match, the stick wont fully fall into the next gear and it will lightly grind.
In my old Nissan I did clutchless shifting quite a bit. I learned about it from a trucker and after awhile did it all the time. Can't race with it I don't think, because it's just at certain RPM's. I doubt it saves that much wear because you can't go from neutral to 1, I usually did it to impress my friends. I don't think going from gear to neutral without the clutch is bad either.
yea, it seems just a fun way to screw around and test my driving ability. Don't wanna wear out my synchros prematurely tho, so i'll stick w/ the clutch. thanks guys, this board rules!
There is nothing wrong with doing this during normal driving... if you're good at it. I do it quite frequently when I get really lazy and don't feel like using the clutch. LOL I learned to do it by driving semi's though, so I've had quite a bit of experience. It can be alot of fun to do, especially downshifting.... sounds cool too once you get the hang of it. Its also fun to impress friends and confuse my girlfriend.
you know if you really think about it...if you didn't want to wear your clutch or synchros you could use the clutch but rev match and dump the clutch...this would be the same as rev matching without the clutch except less wear on synchros...or so it seems to me...i may be wrong
