question for the pro 5.0 fellas
so ive had my pro 5.0 for about 2-3 weeks now, and i have had to tighten the stick twice. it keeps coimg loose. does this happen to anyone else? should i just get some longer bolts and get some nuts for em? and i want to get the lous SS should i just hold out and wait till i get this?
Originally Posted by gettinthere
I just keep an allen wrench in my console. It needs tightening every few weeks or so. It takes 15 seconds at a stoplight.
Just use the blue loctite, that will be the end of your bolts coming loose. I would never use the red stuff unless you want them in there permently, or use a torch to heat them up to remove them. If you want an LSS, then I would just get an LSS. Cutting your stock stick is not the same thing regardless of what people might think. If all your looking for is a shorter stick then that's cool. But if you want a shorter stick with a nice angled feel to it, the LSS is a nice piece, or one similar like maybe the $20 UMI one, haven't tried that one though...
Dan
Dan
Originally Posted by 01 Red WS6
so is your console apart so you can tighten them? Seems like alot of trouble just to tighten something when you could spend a few dollars to fix it and not have to mess with it anymore.
Nope. I unscrew the **** and take off the boot. Screws are right there. Tighten them and put it back together.
i just bought new lock washers. The ones that came with the PRO-5.0 were not that strong. They got stretched out really easy. Never had to mess with it but once since then. Been a while, too.
