Best Clutch for me?
Best Clutch for me?
Im doing a A4-M6 swap...i am pretty sure im going to be using
a B&M Ripper (gotta see what it looks like still installed), Performance/Street built T56 from FLP or Speed Inc, SLP 12 Bolt Posi w. 3.73 pose 33 spline, 1350 yoke, 8.875" axles.
By the time this happens I plan to have a Full bolt on setup:
Headers, GMMG, my intake, Ported TB, Pulley, Tune
I also plan to run most of my suspension:
SFC's, LCA's, adj. T/A, Sways, Adj. PHR, STB
If a cam or head/cam itll be no higher than 450 rwhp and torque. Most likely around 415 rwhp and 430 rwtq or somewhere not to far form there but that will be AFTER the install.
Since this will be a Daily(rain or sun), will see more than enough track time (dumping at 4000+), and ROAD RACING
What i need is a tame clutch, that will grab like a **** and last me quite a long time. Go in easy and alost activate off an idle, and give me reliable shifts. Durable, Reliable, Long Lasting, and Streetable
My toss up is from what I've seen (I did use the Search Button) Spec Stage 3, Clutchmaster, Ram, or Mcleod? I want to kno which brand clutch, which model clutch, and what to expect form that clutch
Spec stage 3 or 4 would be fine...One of my friends has a stage 3 and he launches at 5500rpms on gas. Another friend of mine has a stage 4 (which is not recommended for street use) but its his daily driver and loves it...I will be going with the stage 3 with for my bolt on car...
Originally Posted by 02WS6Bird
how is he McCleod Single disc? hows it compare to Stage 3's?
