T56 trouble
you may also be having clutch problems.
I'm definately gonna put some dexron III in it this weekend and see if the thicker oil helps out a bit.
1.) Which Royal Purple, their MAX ATF or their Synchromax?
2.) When you find the real cause of the problem, whatever it may be, can you please update this thread so anyone using it to search on people's fluid experiences in the T-56 can have some reference?
Thanks, and I hope you get it worked out for as little $$$ as possible!
Chuck
i'm not really sure which one it was but the synchromax sounds familiar also i will post the results of what the problem is. I'm a little pressed on cash right now because of school so i'm gonna change the fluid this week and check for any major damage and if it's still driveable i'm gonna drive it until i can afford a built up t56
thanks for your input
cmac
First I've heard of the Synchromax not giving good results...Royal Purple has plain bad showing with their MAX ATF and now a bad result on the Synchromax.
Just for research sake, what went back in their as far as brand of dino Dexron III?
Thanks for posting the results back by the way!!!
Chuck
