Flywheel Resurface or not?
I have a 2000 Z28. I recently purchased a spec stage 3 clutch, my car is fairly stock with bolton. Id say maybe 350 flywheel hp. Should I purchase a new slave and master, also will the stock flywheel work fine as long as I get it resurfaced? car has 23,000 miles on it may see the track once every 2-3 months if that.
any info would help!!!
You might want to price out what the 02 slave and master cost and compare it to the mcloyd slave and master.They are a bitch to bleed, have someone who knows what there doing bleed it out or your gonna drive yourself nuts trying to do it. You need 2 people to do it
From what I've gathered, the stock flywheel can only be turned .020 to .030. That isn't much, and more than likely you'll need to take off more than that. I would would recommend replacing the flywheel.
I wouldn't bother replacing the master, just the slave; the master was the same, it was only the slave that got upgraded.
With only 23K on the car I would think the flywheel would be fine. If you get it resurfaced make sure they tell you how much the took off and install a flywheel shim to make uo the difference.
I took a chance by accident.
My mechanic didn't resurface my flywheel, even though I asked him to. He said it looked fine ( ).
So far though, lots of abuse and my Spec 3 is holding up.
I only had 18k on my car when I replaced the clutch and flywheel. My clutch was toast and the flywheel was a mess. I don't take chances. If your flywheel looked anything like this, then you should have chucked it...
someone likes to slip the clutch trying to avoid a
