spring broke on clutch pedal
so i'm driving down the road at about 55 and go to shift to 6th gear and i hear this loud pop sound come from below the dash, i then feel something hit my foot. i pull over and see what looks like a piece of broken spring. i was a couple of miles from work so when i got there i pulled the panel off below the driverside under the dash and see a black spring wich is still partly attached to the top of the hydrolic arm. the clutch feels i little bit less springy but the car drives and shifts fine and there is still some play in the pedal so i don't think the throw out bearing is riding on the clutch. i called the dealer and they want 35 bucks for this shitty spring. i then called napa and advance and they dont carry it. how big a deal is this spring if it comes off, i am going to put one in today or tomorrow, even if i have to go to home depot and make one. what do you guys think, has this happened to anyone before? thanks
Changing that spring is a big PITA... you'll see what I mean if you crawl under there and look. Gotta remove/move quite a bit of stuff to get at it.
Mine broke (for the 2nd time) 2 years ago and I never replaced it that time... car shifts fine, and I've never noticed any kind of a difference. And I do quite a bit of drag racing with this car...
thanks for the info, i looked at the spring and it looked easy to replace, but since i have never done it and you have i believe it will be a PITA. what is the hard part, getting to it or just removing it and putting the new one in.
thanks
thanks
thanks
thanks
I think this just happened to me this morning on the way in to work.
I pressed the pedal down, and heard what sounded like a spring breaking under the dash. I didn't feel or hear anything drop on my foot or the floor though.
The car does feel fine and seems to shift ok - like Tranzor was saying.
What is the point of the spring if it's not needed? Surely it does something. I'm tempted to replace it. Just not sure if it's worth it. Especially if it breaks in 6 months.
Same thing happened to me about 20 miles after my LS7 clutch install. That was 250 miles ago and I haven't had anything go wrong yet. Pedal still feels fine and returns quickly. Mine probably happened from pumping the clutch pedal ~2000 times while I was unsucessfully performing the factory preferred clutch bleeding procedure.
The LS7 clutch is a bit stronger than the stock LS1 clutch, I would suspect (hence the reason for doing the upgrade, right? lol). I can't help but worry that the clutch might be slipping if it was designed to have a spring on the pedal.
On the other hand, the reduced tension in the pedal (which feels much softer, almost squishy now, like it's "sprun" by some temperpedic foam material) makes shifting much smoother, which I imagine is easier on the various mounts, rear, and people inside.
Any technical data on the purpose and intent of the spring would be appreciated greatly.
I'm also wondering if there is anyway to mod the system a bit to make it easier to replace. If it's going to break so frequently, it would be nice to carry 1 or 2 and when it breaks, be able to just pop it out and a new one in, on the spot, quickly and easily.
Originally Posted by MrDude_1
its common that they break.
but they're jsut there to help with the clutch feel.. thats it.
so if you dont mind it feeling a little harder to hold in, and a little lighter as you initially press it in, then you're fine.
happend to me too, you cant make this thing...so buy it from the dealer and see if one of the guys in the service dept can put it in for you...thats what i did, it was 35 bucks and the guy put it in for free. it took him 10 minutes
Yeah i know that clip!...while i was reconnecting my master cylinder and laying on my back on the floor...pain in the A$$
...i noticed the the clip had worked its way out of the metal bracket and further onto the spring...so that the spring was contacting the actual metal bracket...so i removed the spring...the clutch safety switch..and the brake light switch..and pressed the white clip back in place...and worked the spring back into place...10 minutes of bull for a lil peace of mind
![Bash](https://ls1tech.com/forums/images/smilies2/bash.gif)
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
