leaky rear seal on T-56, common problem?
i was told by a trans shop that some of the Yokes on these cars have a "vent hole" on them.. which causes the rear seal to leak. He told me that what they do to solve the problem is fill the hole up, because its not needed since there is already a vent on the T-56..
has anyone had experience with this or know what im talking about? i dont want to screw up this trans.. its new
yeah its leaking from that rubber boot to the yoke.. the trans is brand new, because the last one burnt up because of this rear leak.. this trans has about 1500 miles on it.. and i have a silver dollar patch size on the driveway from the leak.. i got under the car and its leaking from there..
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
Look inside the yoke for wear to the splines.If you have too much wear, the yoke will move too much for the seal to work. Yokes are not hardened steel. It may have been the yoke fit that took out your first trans. Do you have vibration?There should be no scoring of the outer yoke surface either.
i have the same prob but i have put 2 seals on and can't get the iner ring to go over the tranny shaft can someone please help also the outer side of my ds yoke has some marks on it but i think it was like that when i got it?
thanx in advance
thanx in advance
Originally Posted by KiLLJ0Y92Z28
replaced the seal 2 times already.. dont suppose you know the correct diameter of the yoke then?
anyone have a set of calipers that can check thiers?
What seal are you using?? I would get the GM seal. It is WAY different than the aftermarket. There is a big rubber shroud around it. My rebuild kit came with a cheap aftermarket seal. I tossed that and got the GM one.
I had 113k at the rebuild. It did not leak before and does not leak now.
Good Luck
