Rebuild my tranny or buy a built one ?????
you can buy them from www.ls1speed.com they are a little pricey. Or you can order parts from d&d (http://ddperformance.com/t56_partsupgrades.htm)...typical labor at shops is $250. d&d also sells them (http://ddperformance.com/t56__6_spee...nsmissions.htm)
Eric rebuild it. Go talk to your local GM dealer, ask for the tranny guy up their. See if he would be interested in rebuilding it on the side. A local guy here can do it for 300 labor and u buy the parts. You can get the parts from Southern Gear, or D&D and save some money.
Mike
Mike
Originally Posted by FCar2000TA
I've heard that the D&D trannys aren't basically a stock tranny.
Which should I do???? I want the tranny to handle 550 ft/lbs of torque
Just an FYI the stock tranny is not rated to 550rwtq. So if you want it rated to that you need to get it built to handle, not a stock replacement.
Your first post
They have tranny's for 500rwtq for $2000.
So.... lets say I rebuild it... Lets say I get the parts form D&D... what parts do I need? Do I need the viper output shaft conversion? I figure I need everything except for the gears and the viper output shaft. I may need gears, I'll have to wait until I see the gears that are currently in.
