Brass Pilot Bushing
Old Jul 5, 2005 | 09:19 PM
BR1060's Avatar
Question Brass Pilot Bushing
Allright, so the Tranny Guy Fixed my Tranny. But before I put it in, he said that I should think about getting a Brass Pilot Bushing. I purchased the Spec Stage 3 Clutch, does it come with a Brass Pilot Bushing?? Where can I find one??
Old Jul 5, 2005 | 09:40 PM
Country Boy's Avatar
Senior Member
Why?! We have roller pilot bushing/ bearing Youre tranny guy might not be a very good tranny guy Roller > brass
Old Jul 6, 2005 | 12:22 AM
TPICamino's Avatar
Any local parts store will have a brass pilot bushing. A roller is not necessarily better. If a roller is installed improperly, it will make lunch out of an input shaft when it lets go. The brass bushing is the timeless standard and it doesn't shoot out bearing fragments if, however unlikely, it fails.
Ryan
Old Jul 6, 2005 | 06:56 AM
calhoon's Avatar
Brass wears where the bearing does not. If they are both installed correctly , the bearing will be the better part- always.
Old Jul 6, 2005 | 08:55 AM
sabre81's Avatar
Brass wears, bearings do not??? sure they do. All metal on metal contact will cause wear. The reduced friction through the use of bearings do reduce wear of course.
However, bearings can fail , brass bushings most likely will not.
I vote for the brass bushing.
Old Jul 6, 2005 | 11:03 AM
calhoon's Avatar
The relative wear to the bearing is nil compared to a bushing. Do what you like, put that 1940 style composite brass / low speed part in YOUR LS1 . I would choose the bearing, as original.
Old Jul 6, 2005 | 03:29 PM
Senior Member
+1
Old Jul 6, 2005 | 03:35 PM
1madss's Avatar
I would agree that the brass bushing would be less prone to coming apart/deflecting. But if your input shaft is deflecting that much you've got bigger problems
I just replaced a pilot bearing with over 95K miles on it. It looked just like the new one from the dealership.
