what clutch fluid?
Old 09-23-2005, 11:34 PM
MustangEater82's Avatar
Default what clutch fluid?
what are you guys using as a clutch fluid?
Old 09-24-2005, 03:21 AM
Ferocity02's Avatar
Anything will work. I dont think there is really a "high performance" brake fluid. I used some made by Valvoline.
Old 09-24-2005, 09:06 AM
I had the valvoline stuff was turning black on me every 3 months...
recently put in a dot 5 silicone one when I did my Master, but noticed Chiltons, says not to use silicone and some other type ones, that it might break down the internal seals. And use GM or equvailent...
not looking ot ever do a clutch master on my car ever again Wanna use something safe.
Old 09-24-2005, 11:59 AM
Ryan02SS's Avatar
Valvoline Synpower Synthetic DOT V. Has a higher boiling point than conventional DOT III.
Old 09-25-2005, 08:54 PM
kenp's Avatar
I used the valvoline synpower and so far so good.
Old 10-01-2005, 10:43 AM
GoatChs's Avatar
In fact, there are high performance brake fluids. The measure of hydraulic brake/clutch fluids are viscosity at given temps, wet and dry boiling points, and resistance to hygroscopic suspension (water absorption which causes spongy pedal).
WARNING! DO NOT USE SILICONE-BASED (DOT 5) FLUID!! Silicone-based fluids will deteriorate your master & slave seals and you will eventually have to rebuild both. If you must use a grade better than DOT 4, use the new DOT 5.1 which is a compatible glycol-ether base like DOT 4. Great info HERE
The following fluids are the top rated DOT 4 fluids in the industry. All are compatible with normal driving and service intervals (not like race-only fluids that require flushing every 3-4 months from just sitting!):
I recommend Motul RBF600...
Old 10-01-2005, 11:06 AM
DONAIMIAN's Avatar
ATE superblue. In my brakes, in my clutch.
Old 10-02-2005, 08:21 PM
A-Bomb's Avatar
DOT 4 here. i can't remember the name though.
Old 10-02-2005, 11:13 PM
YOOFORMULA's Avatar
I used ATE in my Mcleod and it tore the seals apart within 6 months. I had to rebuild the damm slave cylinder internals, luckily Mcleod provides a rebuild kit cheap.
Old 10-03-2005, 01:02 AM
A-Bomb's Avatar
Dot 4 Prestone here.
Old 10-03-2005, 02:29 PM
dailydriver's Avatar
Neo 610 here. It's what Cartek uses pre-filled in their systems for their clutches. The Motul RBF 600 & the GS610 are also excellent (though the latter is prohibitively expensive, even more $$$ per volume than Castrol SRF!!!).
Quick Reply: what clutch fluid?
