Can the factory clutch Hold this power ?? >>>
Hi all ,
I think some of you know what my car has , but some else don't ......
So my car has
Large Heads , 226 Cam , LS6 intake , Full Intake and Exhaust System , 3.73-for street- , Pullys and so on ...... the problem that I don't know how much RWHP my car has , but from USA guys numbers ..... I can assume that it will be more than 400 rwhp , I hope .....
So , can the factory clutch hold all of this power ?? I am shifting between 6500 - 6600 rpm ...
what you think guys ??
Thanks in advance <img src="gr_stretch.gif" border="0">
So my car has
Re: Can the factory clutch Hold this power ?? >>>
Sorry to hear about the other clutch Abdulla <img src="gr_sad.gif" border="0">
I don't you'll have much luck with a factory clutch by the way you like to launch.
sorry to hear bout your cltch too! good luck with the factory one <img src="graemlins/gr_barf.gif" border="0" alt="[barf]" />
LSX Mechanic
Abdulla, I am sorry to hear about the clutch bro. I know EXACTLY how it feels. My star clutch blew up on the second pass I ever made with it, and then Star told me to go f-ck myself. I'd contact Julio and see if he's willing to do anything for you.
As for the stock clutch, I wouldn't expect it to hold for very long. If you must run one, make sure it's the 02 Z06 clutch, which some people are having good luck with running 400+rwhp applications.
Good luck man,
Josh
Good luck man,
Josh
Thank you very much guys <img src="gr_stretch.gif" border="0">
Let me to say that I don't want this clutch for launchs ..... I want it for roll races , I mean for street races not for drag ......
So can this clutch hold to 6500 rpm ??
Thanks you again guys <img src="gr_stretch.gif" border="0">
Oh man, that is some hard luck Abdulla! <img src="graemlins/gr_barf.gif" border="0" alt="[barf]" />
I think the stock clutch will have a hard time with that much power----even from a roll. Might be OK for now until you can get a better one. <img src="gr_images/icons/mad.gif" border="0"> Might try the RAM!!! <img src="graemlins/gr_hail.gif" border="0" alt="[hail]" />
<img src="graemlins/formula.gif" border="0" alt="[Pontiac]" />
Thank you guys
Yeah Mike , I think I will go with Ram maybe <img src="gr_stretch.gif" border="0">
Good luck <img src="gr_images/icons/wink.gif" border="0">
Thank you guys
<img src="gr_images/icons/cool.gif" border="0"> That is what I am gonna get. I just have to decide do I want the VDS kit for $940; or can I make my own kit like Harlan did and save some dough. <img src="images/icons/confused.gif" border="0">
Abdulla,
I don't think that clutch will hold for sh*t! I had only bolt ons with 4.10s and it was slipping like crazy! specially when I shift to 3rd <img src="graemlins/gr_judge.gif" border="0" alt="[judgement]" />
I dono what to tell you, but from the way you drive(you know what I am talking about) <img src="gr_grin.gif" border="0"> I guess you can use the factory one with no problems
good luck man <img src="graemlins/fluffy.gif" border="0" alt="[Fluffy]" />
I can shift faster than you.
Abdulla, I would see if Cartek would send you another clutch if at all possible. That should not have happened. <img src="gr_sad.gif" border="0">
I still would look into getting a RAM clutch before putting in another stock clutch.
Good luck!
Jason
Good luck!
Jason
GO WITH THE SPEC STAGE 3...IM PUTTING DOWN 577 TO THE WHEELS WITH A PRO CHARGER, HEADS AND CAM, AND IT HASNT SLIPPED ONCE...
Abdulla,
I would go with the RAM 402/6130 setup if you do need to replace your old one. The price is right, about the same as a stock and it holds my 6600rpm dumps without blinking. Joe K has also attested to the longevity of this setup. I also went through a Cartek in about 4 months, but it was my fault that it failed. I had adjusted the master too high to try and get it to disengage fully after launch. What I should have done was the drillout mod.
Mark
Mark
I used to push 420rwhp on my stock 01' clutch.
Like i said, "I used to push". <img src="gr_sad.gif" border="0">
