tq specs?
examples
trans to bellhousing
bolts that hold drive shaft on
flywheel
pp
slave
bellhousing to motor
crossmember
ext....
slave = 6 ft lbs
driveshaft = 16 ft lbs
flywheel = 74 ft lbs (15 then 37 then 74)
PP = 50 ft lbs. (35 then 45 then 50)
Trans mount nut = 77 ft lbs
Trans support = 66 ft lbs
Dont forget to clean the clutch disk, flywheel, and pp mating surfaces with brake cleaner before installing to get any grease, oil, or body oils off so as to not contaminate the material. Also, apply white lithium grease on the splines and the end of the transmission input shaft. Last but not least, while installing your transmission, remember to loosen the bleeder vavle on the slave cylinder otherwise you will probably not be able to push the transmission all the way on. Good luck and have fun.
