Textralia Hydraulic line(SS braided)
Does anyone know when Textralia's new hydraulic line is coming out for the f-bodies? They said they were making a line that is larger than the factory line and would be an alternative to the drill mod and work better. Anyone have updated news on this?
-William
-William
i found in another post you can buy the two fittings to make the master and slave 4an fittings and just buy the lines and fittings it would delete the quick disconnect though like the mcleoad kit has but at 150 dollars i willl make my own if the textralia kit is too expensive i will be making my own also so i can make it a little longer
Originally Posted by Plan B
Thank's Byun,
We have the Aussie cars set and the Corvette units are now ready.
f-bodies will happen when we receive the sample.
2-4 weeks Max!
Cheers
Pete.
2-4 weeks Max!
Cheers
Pete.
-William
not to be off topic but meentss02 ide thought you would enjoy this thres from ls1.com
http://ls1.com/forums/showthread.php?t=8852
Originally Posted by YoungB@BYUNSPEED
I depised that site. They force you to register in order to read posts. It's only to get their registered user number count up.
*sigh*
I guess I'll stop hijacking the thread...please keep us updated on this new part. Real world use reports would be nice as well
Originally Posted by 99blancoSS
What issues? I've got a 99 and have never had any trouble at all, except for having to replace the stock clutch with a textralia to support the power.
when you clutch fast, all the fluid doesnt come back because of the restriction.. clutch fast again, and you'll find even more doesnt come back in time..... its hard on the clutch, and transmission.
the drill mod drills on one of these restrictors. this usually makes it tolerable, and makes the clutch feel better.
however, restrictors do remain in the line... a replacement line would fix that.
the main holdback keeping us from making our own lines, is that the connectors for the master cyl and slave cyl are GM only... they arnt common connectors, so you cant just buy them off the shelf.
Originally Posted by MrDude_1
the stock SS clutch line has a couple built in restrictors in it.
Here's an update.
really, if someone would just make the fittings to go from the two connectors to AN fittings, that would be awsome.. then just some small braided line, 2 fittings, and we'd have a normal hyd clutch..
