View Poll Results: witch type of fluid
1.
0
0%
2.
0
0%
3.
0
0%
4.
0
0%
Voters: 0. You may not vote on this poll
witch tpye of trans fluid (not whatbrand but what type)
Old 01-05-2006 | 08:36 PM
bad6as's Avatar
Default witch tpye of trans fluid (not whatbrand but what type)
1.
2.
3.
4.
im prety sure im ruling out number 4
i put number 2 in there a while ago to help my grinding, it helped but of corse it dident fix it. so when i get the trans back from Joe i want to get whats right. he said something about syncomesh but im still unsure.
Old 01-06-2006 | 04:46 PM
chpmnsws6's Avatar
just checking in as i need to know also
Old 01-06-2006 | 11:25 PM
bad6as's Avatar
any one?
Old 01-07-2006 | 12:32 AM
chpmnsws6's Avatar
i don't think anyone knows what kind of tranny fluid to run
Old 01-07-2006 | 01:24 AM
01formulafromthebay's Avatar
I have GM syncomesh it works fine for me in my M6
Old 01-07-2006 | 01:28 AM
chpmnsws6's Avatar
so is that ATF?
we aren't looking for a brand, we are more looking for a weight (or atleast i am)
Old 01-07-2006 | 10:58 AM
wrencher's Avatar
wrencher
GM recommends ATF III it is automatic trans fluid. A good quality ATF will work fine.
Old 01-07-2006 | 12:54 PM
chucky2's Avatar
Most Dexron III ATF's are in the 7.5cSt range at 100 C.
If you look at the Amsoil (since you listed Amsoil lubes) MSDS website - presently located here - for each of those that you listed, you can see the cSt at 100 C for each of those lubes:
#1 (Amsoil ART): 7.09 cSt
#2 (Amsoil ATF): 7.48 cSt
#3 (Amsoil MTF): 9.06 cSt
#4 (Amsoil MTG): 14.73 Cst
Out of those 4, the Amsoil ART or ATF is going to be closest to the factory fill. The MTF will be close to a Synchromesh lube, as those are usually in the 9.1 cSt range. The MTG is probably going to just be too thick for use, especially when cold. Not that I'm an expert or anything, but if I had one of your cars, I certainly wouldn't use the MTG in it.
It's interesting to search for 12345349, which is GM's part number for non-Friction Modified Synchromesh. Searching over at BobIsTheOilGuy.com forum, I ran across the following threads where pgtr over there did some good research on this spec. The threads are located below:
RL D4 ATF vs Synchromesh
More pieces to the Synchomesh puzzle
The above 2 threads from over at BITOG should answer questions on weight of Synchromesh.
You could also take a long and careful read through this long going thread here: Which T56 fluid?
Hope some of this helps...
Chuck
Old 01-07-2006 | 01:20 PM
Rob's Avatar
Rob
Royal Purple synchromax
Old 01-07-2006 | 06:32 PM
chpmnsws6's Avatar
trash can. once you go amsoil, you never go back
i work at a store that sells royal purple and i still don't buy it (even though its MUCH cheaper then amsoil)
Old 01-07-2006 | 06:33 PM
chpmnsws6's Avatar
Chuck
thanks!!!! thats all the info i needed
Old 01-07-2006 | 07:48 PM
tici's Avatar
With my 97 Borg Warner (40'000 miles) I tried a couples of fluids:
BP mineral Dexron III: I had the feeling it was notchy, good shifts.
Agip synthetic Dexron III: notchier, easy to grind (very easy!).
GM synchromesh: less notchy than the BP fluid, good but slow shifts, especially at low temperatures.
At the end I went back to the mineral Dexron III: it shifts like a dram! just a little bit notchy and it shifts fast at low temperature also.
Definetly better than Synchromesh. Strange I didin't like it before.
It could also be the rest of the Synchromesh mixed with the new fluid... is it possible that a little quantity modifies the properties of the Dexron III?
Old 01-08-2006 | 01:05 PM
Rob's Avatar
Rob
Really. I've run both and RP seemed better. What didn't you like about it?
Old 01-08-2006 | 04:03 PM
bad6as's Avatar
whoa mt airy, me too,
Old 01-08-2006 | 07:43 PM
Rob's Avatar
Rob
Cool. Maybe I've seen you around and didn't even know it
I'm easy to spot, blue GTO. Think I'm the only one in town. There is another blue one but his is the more greenish blue(barbados blue)
Old 01-08-2006 | 09:34 PM
chpmnsws6's Avatar
just seems to last longer and i've heard ALOT better reviews on the AM..... but then again the RP does look a perty purple and the gear lube doesn't smell to bad haha
Quick Reply: witch tpye of trans fluid (not whatbrand but what type)
