would a bad slave cause this?
Anyways, for some reason unknown to me, my car's clutch pedal seems to stay stuck on the floor whenever I do a WOT run. It will not let me shift or pull the tranny out of gear (usually happens in 1st, but it has happened in 2nd before). Sometimes I pull the pedal back out with my hand, but when I go press it again with my foot, you can tell there is absolutely no pressure and it gets stuck to teh floor again. About 10 or 15 seconds later, it'll regain pressure and I can drive normally again.
It only happens at WOT, it drives absolutely perfect in regular everyday driving. I'm by no means a tranny expert, but it sounds to me like a hydraulics problem. I replaced the master cylinder about a year ago (so I'm assuming it's still good), and I can see no visible leak of hydraulic fluid. Could this be the slave cylinder going bad? What else could it be?
Thanks for any help!
, but either way the problem isn't the drill mod. I'll just replace the fluid and bleed the system once I get some free time. The Best V8 Stories One Small Block at Time
