SPEC is dead
No trips to the track, no big street clutch dumps. Just wanted to get off the line at a light very quickly, let the clutch out and floored it & the clutch took a dump.
There just aren't words to express my sincere thanks for high quality and durable SPEC product that took hours and hours to install and is now JUNK as I guess it was from the very beginning, after only 4800 miles.
My Sincere Thanks.
The car runs fairly strong but loosing a clutch under these conditions with so few miles is ridiculous.
I guess I'll look at an upgrade to the LS7 or maybe just go back to the Z06 config. I've had my fill of aftermarket crap.
The OEM Z06 lasted 34K and it was smoothe. This aftermarket stuff basically sucks. I put up with 1K miles of ridiculous chatter and continual chatter in reverse, and then it just gives out. That's BS. If the OEM stuff were not any better than this aftermarket stuff, there'd be a class action law suit against GM.
I could have gone a cheaper route with the Z06 parts but the RAM disc is made out of heavier material and is less likely to fragment and my Fidanza is SFI rated. I won't have the parts until late February and that's ok because it'll probably be more likely I'll have warmer temps to do the work. And I guess I'll go ahead and put my 4.11's in when I do the clutch. If I feel real ambitious, maybe I'll put my 02 Z06 heads on too.
The decision is made!
I feel your pain.
