Downshifting
I would even state shifting it into any lower gear would fight against you in a panic stop because the engine rpm would not normally drop as fast as you're forcing it to. You would actually be using a portion of your car's braking ability to slow down the engine internals and flywheel. In anything less than a panic stop this would not be the case, so using the engine to brake would suppliment your relieve wear on your brake system over time. It does not contribute to a shorter 100-0 distance though.
I personally downshift nearly always while coming to a light or off an offramp. I rev match whenever I downshift, so the wear on the clutch is minimal. It saves quite a bit of time on the brakes and guarantees I'm in the right gear to accelerate if some goof ball decides to do a last second lane change. Nothing like having all options available at all times... even if you're just pulling up to a stop light.
I don't know how you guys can say that downshifting doesn't slow your car down more because you can feel it when coming to a stop on flat or hilly surfaces. Oh well, Ill continue my rev-matching and downshifting. I like to do it anyway, hence the 4:10's.
Just normal braking with car in neutral for stop lights and most slowing.
My reasons: wear and tear, fuel economy.
Its always the people slower than me that want to race. Except for that one z06. I need more mods.
but as far as street driving i dont see the point if you're just cruising, ESPECIALLY in southern california where i live. there's just too much traffic...and these guys who are saying it "saves them gas" where do you come up with that? when you're coasting to a stop light - throw the car in neautral, then the motor will be at idle, meaning less revolutions meaning less gas. if you downshift then everytime you rev match into a gear you open the throttle giving the motor more gas to burn and then it's suspended in this fall where it's going to be burning gas from whatever rpm until you downshift into the next gear and rev again. basically constantly burning gas for no point.
even if the throttle isn't open, the motor still needs gas to spin the additional revs.
