only 5k on it and it failed
Old Feb 21, 2006 | 02:26 PM
blkchevyz's Avatar
Default only 5k on it and it failed
http://www.mofbody.com/blkchevyz/clutch.jpg
http://www.mofbody.com/blkchevyz/clutchfly.jpg
Old Feb 21, 2006 | 04:31 PM
98whitez28's Avatar
damn! so what are you gonna use next?
Old Feb 21, 2006 | 04:41 PM
ibanez7's Avatar
ouch let me guess it was a spec....
if your on a budget try the ls7 clutch its rated to handle your hp...
Old Feb 22, 2006 | 06:34 AM
blkchevyz's Avatar
i guess this is a common thing for specs?
im an lt1 so no ls7 clutch for me.
since my flywheel is ate up, i might just save for a street twin.
Old Feb 22, 2006 | 10:26 AM
ibanez7's Avatar
yeah its common for specs to crap out early.
check out ram clutches... cost about the same as spec.
Old Feb 23, 2006 | 10:48 AM
blkchevyz's Avatar
well spec did me right on a new one so i'll see how it does.
Old Feb 25, 2006 | 01:59 PM
mike c.'s Avatar
yeah,check out ram clutches because they never crap out early well....i had the ram 980 lasted 1,200mi motor only no nos. my ram 910 lasted about 1,500mi and was gone. the spec st3 lasted about 2,000ish mi but took WAY more punishment then my two rams ever did. so now i need a new clutch also.i feel your pain bro.
Old Feb 26, 2006 | 01:25 AM
BirdofPreyBandit's Avatar
I've had my Spec III clutch for about two years with about 20,000 miles. I didn't race too often. Maybe about 2 passes a month or so. It worked fine but just started to slip. Most likely going to go with the Textralia and see how that works out.
Old Feb 26, 2006 | 07:09 PM
WS6FTW's Avatar
I've had my Centeforce DF in for not even 500 miles, and it feels like ****. A lot of play at the top, only engagees way low, and all around feels bad. I'm calling centerforce, I want them to pay to fix it or give me my money back, do not use centerforce.
