View Poll Results: What Clutch are You Using? (select one or more)
LS1 (Stock)
341
21.05%
LS6
152
9.38%
LS7
182
11.23%
Textralia OZ700
115
7.10%
Textralia Exo-Skel
36
2.22%
SPEC 1
18
1.11%
SPEC 2
45
2.78%
SPEC 2+
33
2.04%
SPEC 3
192
11.85%
SPEC 3+
108
6.67%
SPEC 4
23
1.42%
SPEC 5
26
1.60%
McLeod Single Disc
41
2.53%
McLeod Twin Disc
78
4.81%
Ram VDS 300
4
0.25%
Ram VDS 900
4
0.25%
Ram VDS 980
6
0.37%
Ram VDS 910 "Race"
10
0.62%
Ram HDX
6
0.37%
Ram Powergrip
21
1.30%
Ram Powergrip HD
87
5.37%
Exedy Hyper Single Disc
5
0.31%
Exedy Twin Disc
14
0.86%
Centerforce Dual Friction
132
8.15%
Hays
4
0.25%
SLP/LS6
17
1.05%
ZOOM
12
0.74%
Luk Pro Gold
20
1.23%
Multiple Choice Poll. Voters: 1620. You may not vote on this poll
What Clutch is Everyone Using?
#305
Am I the only one in the US that used the Mcleod Rev-Lok II Sintered Iron Disc Clutch? Before my car was totaled it had HUNDREDS of 5k plus launches on ET streets and ET Drags and it NEVER slipped!!! I also drove it on the street for several years and it was street friendly!!! No one else has used this clutch? They had some problems originally, but the revised one came out around three years ago and it was awesome. When I bought it it was around $450.00 Last I heard it was much more expensive. This clutch was abused and NEVER missed a beat!!!If I get another M6 there is no doubt in my mind I would buy it again!! My .02
Paul
Paul
Paul
Paul
#308
My first St3 Spec had to be replaced due to severe vibration. The 2nd one was ok, but they put a sour taste in my mouth. Acted like I installed it improperly yadayada. Then admitted their balance equipment was out of cal or something like that. I also got tired of the engagement roughness as a daily driver. They probably serve quite well in racing applications, but don't seem to hold up very long in a driver.
#310
LS7 Clutch
Just replaced stock LS1 clutch with LS2/LS7 combo. High holding torque, stock pedal feel, and all with the comfort that it is a stock GM product. No slip at all. I would highly recommend this clutch. Go to Scoggin Dickey (sdparts.com) for the $399 clutch/flywheel package.
#316
I'm using an LS6 clutch right now and i have about 14k on it. But i know i have too much power for this clutch now so what clutch do you guys recommend for a car with around 500hp and 600tq?
As the car sits right now it had 431hp 555tq
#317
i have a ls7 but it slipped on me after 12k and a hand full of 5k+ dumps on m/t et streets (cheater slicks)
so im in the market for a new clutch set up and flywheel. wait if i was to get a clutch disk and pp from a ls2 i guess i could reuse my flywheel, do i need a vette or gto clutch? vette right?
#319
Ok have my twin tex but only at about 420engine hp still twin turbo kit is not installed was hoping to do it in spring on a built 408.
I am shooting for 850rwhp on turbos and possibly 1000rwhp on small shots of spray.
This would be occasional max power as most of the time think would be running 700rwhp in daily use. Car is not a track car only a street car. Might see a couple of drag strip runs and dyno runs but will never get a cage.
So will my twin stand up? Should I sell it and go to a triple or add on to the twin not sure how that works exactly. Who is running that 850 to 1000rwhp range with their tex twin or triple and how is it holding up? I guess other options might be spec twin or 3plus or spec 5,not a fan of mcleod. Exedy is way too much money.I thought my tex would do the job but now seeing some failures it seems at much lower power than I plan on making.
#320
i will be going with either the LS7 or Textrilla
I am still debating between the 2. I had 415 RWHP and my stock LS6 clutch jsut laughs at me everytime i got WOT....
Where is the best place to get the Textrilla? And what is a good competitive price for the Textrilla?
I know where i am going to get the LS7 if i go that route.
Also how kuch can the LS7 cltuch hold at the rear???
