View Poll Results: What Clutch are You Using? (select one or more)
LS1 (Stock)
341
21.05%
LS6
152
9.38%
LS7
182
11.23%
Textralia OZ700
115
7.10%
Textralia Exo-Skel
36
2.22%
SPEC 1
18
1.11%
SPEC 2
45
2.78%
SPEC 2+
33
2.04%
SPEC 3
192
11.85%
SPEC 3+
108
6.67%
SPEC 4
23
1.42%
SPEC 5
26
1.60%
McLeod Single Disc
41
2.53%
McLeod Twin Disc
78
4.81%
Ram VDS 300
4
0.25%
Ram VDS 900
4
0.25%
Ram VDS 980
6
0.37%
Ram VDS 910 "Race"
10
0.62%
Ram HDX
6
0.37%
Ram Powergrip
21
1.30%
Ram Powergrip HD
87
5.37%
Exedy Hyper Single Disc
5
0.31%
Exedy Twin Disc
14
0.86%
Centerforce Dual Friction
132
8.15%
Hays
4
0.25%
SLP/LS6
17
1.05%
ZOOM
12
0.74%
Luk Pro Gold
20
1.23%
Multiple Choice Poll. Voters: 1620. You may not vote on this poll
What Clutch is Everyone Using?
Old 06-12-2006, 11:45 PM
  #101
~JOSHUA's Avatar
My stock '02 LS6 is holding perfectly after 40k miles of straight abuse and around 20 track passes. Car currently makes 421rwhp.
I don't know how much longer it'll hold out when I bolt on the twin turbo kit though.
Probably going with an aluminum LS2 flywheel/LS7.
Old 06-13-2006, 10:54 PM
  #102
MYTFASTSS's Avatar
FWIW, I will never recommend anyone to buy SPEC. Try it out if you like, But You will be disappointed. Mine didn't just wear out, but one of the springs dropped out upon removal meaning it was already broken. Don't even get me started on the chatter!!!!
I'm very happy with my LUK Gold clutch. The diffrence is night and day. This clutch is a blessing. Feels stock, but grabs nicely without that dam chatter.
Old 06-14-2006, 06:47 AM
  #103
License2Ill's Avatar
Spec is synonomous with "your springs will fall out kid, what r u crazy?"
If I was running a spec I wouldn't wait for it to fail, I'd take it out and replace it with a clutchnet.com or a valeo if money was low. Then I'd tie it the back of my rearend but long enough so it hangs behind the license plate with a sign sayn "spec is dookie".
Or I may modify it by simply shaking it a few times, until of course the spring would fall out, enlightening it so I can Frisbee it with a dog.
You can paint an arrow on it and spin it around to use it for spin the "clutch".
I wonder if I were to tie one to a tree during a hurricane, if the springs would fly off?
I can always leave the springs in tho, and sell it as a ninja weapon... instructions reading : "fling this towards your enemy, as it zooms by them, the springs will automatically release piercing their neck areas and they will bleed to death."
If I fidget with it enough I can prolly turn it into a really cool hubcap. It's kevlar material may never rust and protect me from bullets in the ghetto.
I could put it over my head when I go the beach. And it become the next en vogue item in south beach, it would sell like hotcakes some more!!
I could open up an online bizniz "I weld spec springs in.com" motto reading "tired of these dang spec spring falling out?, for only 19.95 I can weld these for you, or 3 easy payments of 7.97 on your credit card."
My new kick it line to chicks is "my z...yep yep...400hp and a Spec..yep yep" their response??? "lets go to the room baby".
Even Bush has a thing for specs, his plans are to deport them to tijuana if their not registered. Problem like all others...solved.
How many licks does it take to get to the springs in the center of a spec-clutch-blow-pop? (in that order)
Old 06-14-2006, 08:07 AM
  #104
TRANSAM_2000's Avatar
I still have the stock ls1 clutch with about 78,000 miles and it slipping after a few hard runs. Still looking for a good clutch that can take some ****.
Old 06-14-2006, 12:45 PM
  #105
Sawzall and Welder Mod
Whistler's Avatar
Old 06-20-2006, 06:17 PM
  #106
BADBLUE02's Avatar
Mcleod here. It's definately going to outlast my transmission.
Old 06-27-2006, 06:03 PM
  #107
Moderator
davered00ss's Avatar
I never knew there were that many clutches.
Old 06-28-2006, 12:11 AM
  #108
Xtreme57's Avatar
What does a new ls7 clutch kit cost?
Old 06-28-2006, 09:46 AM
  #109
SOMSS's Avatar
Wink
About $635 shipped, that's with a throw out bearing, flywheel, pressure plate and a new slave!
Get one, you will love it, I did!
Old 06-28-2006, 12:30 PM
  #110
bray's Avatar
spec3 here, it does have a mean chatter, and sometimes i get a whinny noise on 1st or rev. engaugement, but man... that bitch grips
Old 06-28-2006, 06:11 PM
  #111
Xtreme57's Avatar
Not too bad. I don't need a flywheel though - i have an aluminum one from spec. So take that out of the equation and that's a pretty good price. Almost certainly gonna be my next clutch.
Old 06-28-2006, 08:31 PM
  #112
Randy WS6's Avatar
Im using a SPEC stage 3 in with my LS6 348cid.with n.o.s. pro fogger 250 shot, in my car right now with no problems at all.But putting a SPEC stage 3+ with my all aluminum LS2 418cid.,with pro fogger 300 shot, that im fixing to install in a few weeks.
Old 07-03-2006, 10:34 AM
  #113
Sartobuilt's Avatar
Default PT #'s
What are the part #'s for the LS7 set up?
Old 07-04-2006, 11:08 PM
  #114
Boodyrider's Avatar
Well, no. The LS7 REQUIRES that you use the LS2 flywheel, so don't count it out. They are NOT the same, and the LS1 style flywheel CANNOT be made to work with the LS7 clutch.
I paid 786.04 shipped for the LS7CLUTCHKIT [which includes flywheel, PP, and disc], and also in that order got a new pilot bearing (roller style), 01+ slave, and 01+ master (Mine's a 98). I also got new clutch bolts. All from fredbeans.com.
Install was straightforward, no spacers needed behind the slave. Both slave and master come full and bled, so after I did the drill mod to the master hose restriction, I just bled the master again over the sink. With both master and slave bled, no bleededing on the car was needed. Some have commented that the pedal starts a bit low; I pumped the pedal a few times with my toes curled over the end, and had the pedal start off dead center of travel.
Even with only a hundred miles the clutch was solid; at 500 miles of moderately hard break-in, including a couple rolling full throttle runs through the gears, it feels as though it'll hold anything my stock engine can hit it with, but I have yet to try a serious launch on sticky tires at the track.
Old 07-06-2006, 02:55 PM
  #115
408 z28's Avatar
just blew the stocker out...ls7 will be here next week
Old 07-06-2006, 03:33 PM
  #116
The gods forecast no troubles for you my friend. Wise move.
Old 07-06-2006, 10:24 PM
  #117
we_todd_did's Avatar
Wow you paid to much for a "stock clutch".
Competion clutchs has a kit everything minus throw out bearing for 499.99. 16lb steel flywheel, 6 puck and a heavy duty pressure plate, you cant beat it.
I have been beating on mine for a while now several track days and not the first problem.
Old 07-22-2006, 09:13 AM
  #118
Wyckedcamaro's Avatar
i JUST purchased the TEXTRALIA OZ clutch and 18 pound flywheel from BYUNSPEED.
Not too bad a price. And it looks like a BEEFY system.
I am putting down HOPEFULLY 460-480 rwhp soon (like next week) so I am gonna need it.
lol
I will keep you guys informed.
Old 07-23-2006, 10:47 AM
  #119
ddnspider's Avatar
Received 1,751 Likes on 1,307 Posts
well for all the spec haters they sure are owning the poll
Old 07-23-2006, 11:20 AM
  #120
just cause alot of people are using spec.. doesnt mean they are working.
Just means alot of people are using it.
Sort of like Centerforce in the older muscle cars.
Quick Reply: What Clutch is Everyone Using?
