smallest shift light?
Old Apr 4, 2006 | 10:44 PM
DriveATransAm's Avatar
Default smallest shift light?
im looking for a shift light for my magnum. when in manual (autostick mode) it revs up so fast past 4K that im never sure where to shift it without keeping an eye on the trach. im looking for a tiny one that i can maybe put in the vent or something (like the old harlans). any suggestions? speed incs site has raptor ones that ive never seen before. they look pretty small. any other suggestions?
Old Apr 4, 2006 | 10:57 PM
Jimmard's Avatar
Harlan still makes the shift light. I bought mine a month or two ago. I like it. I got the blue LED one even tho it was a little more. Well worth the $$$.
James
Old Apr 4, 2006 | 11:02 PM
joshp14's Avatar
Raptor shiftlight is about as big around and long as a roll of nickels. Very small and can fit in a lot of spaces.
Old Apr 4, 2006 | 11:43 PM
Shallow Bay's Avatar
+1 for the Raptor shiftlight
Old Apr 4, 2006 | 11:48 PM
one2run's Avatar
+2! i have mine in the hvac vent also! trick and great product. comes in an assortment of led colors and the housing is anodized in your choice of color.
Old Apr 5, 2006 | 05:02 AM
how does the harlan compare in size/price? how does the raptor work? it said it doesnt use any pills or anything.
Old Apr 5, 2006 | 07:49 PM
beuller.
Old Apr 5, 2006 | 08:08 PM
joshp14's Avatar
www.raptorperformance.com
Here is how you adjust the light...
Old Apr 5, 2006 | 08:20 PM
Ace$nyper's Avatar
I love my harlen
I picked it up from a member here was a total breeze to install and setup.
it's very bright and hidden in my vent AC still blows cold and heat comes fine too.
Old Apr 5, 2006 | 09:33 PM
that looks easy enough. where do you get a harlan at? ive searched and cant find it.
also, how are you guys affixing it inside your vents? this is going in my magnum so i need to figure out how to go about that. do you just tap into any hot, or do you have to tap into a coil lead?
Old Apr 5, 2006 | 11:09 PM
joshp14's Avatar
Shift light has 3 wires...power, ground, and tach. Power and ground are self explanatory, tach wire goes to the engine speed wire from your cars PCM. You will have to get ahold of Chrysler or find a wiring diagram to get this info.
