weird POP + play in the clutch
so today just normally driving after releasing the clutch pedal i hear this loud pop. sounded like it was in the inside of my car maybe my shoe lace got caught on something under the dash or something?? but then i noticed that i had some more play in the clutch and it doesnt catch until i press like 20% down on the clutch pedal!! any ideas???
i looked at the clutch pedal and im not exactly sure what to look for? i hope its just the return spring. all i am experiencing is it takes no effort to put the clutch pedal down to like 20-30% then itll start catching.
Well there could be air in the system, but maybe you were not feeling it as much because the spring was doing its job. Then when the spring broke, there was not as much resistance which could have made it more noticable. When I took off the panel down there, part of a spring fell out and when I looked up there you could see where it had broken. You might try bleeding the hydrolics in case there is any air in it.
Originally Posted by sidewayz28
i dont know how to do that, or do i trust my self enough
For the record, i never fixed mine. Its only job is just to make the first 1 or two inches of engagement not feel squishy.
