DO i need a new flywheels with a new Clutch?
Old 04-07-2006 | 01:09 PM
The PAT WS6's Avatar
Default DO i need a new flywheels with a new Clutch?
I am in the Market of buying a new clutch just cant decide yet between a couple. But my question is will i need a new flywheel as well? And if so which one, i was told my RPM that i will just need the stock one resurfaced, but i have heard its not a good idea.
I plan on either getting a ram Powergrip, or Spec 3, or LS7.
Thanks
Old 04-07-2006 | 01:40 PM
jyeager's Avatar
If you go with an LS7 clutch you need an LS2 flywheel, so in that case you must.
As for the others, well you should be able to get it resurfaced, but if think that the recommended approach is a new flywheel.
Either way, make sure you balance your new clutch/PP/flywheel(old or new). This means a trip to a machine shop and about $50, but is highly recommended.
gettinthere's Avatar
Depends on how many miles you have on the stock one and how worn it is really. When I had my 6 speed, I had my stocker resurfaced and it worked fine. It ony had about 28k on it though.
Old 04-07-2006 | 01:45 PM
TigerWoodsJr's Avatar
i had my stock resurfaced at 55k miles when the stock clutch went, I added a ram powergrip hd and 12k miles of hard driving later it still grabs great.
Old 04-07-2006 | 02:38 PM
Ryan02SS's Avatar
Yes either have the stocker resurfaced or replace with a new one. Keeping a used flywheel with a new clutch is equivalent to putting on a used condom! With the prices of flywheels I would opt for a new one for sure. It's too much work adding a new clutch only to have to do the same process over again the next month b/c parts were skimped on. My .02
Old 04-07-2006 | 11:51 PM
bump ttt
Old 04-08-2006 | 12:05 AM
bigdsz's Avatar
Definitely get a new billet steel one, much preferred over the OEM nodular iron. Thunder Racing has the SPEC's for like $250.
Old 04-08-2006 | 01:18 AM
FUN LS1's Avatar
Originally Posted by bigdsz
Definitely get a new billet steel one, much preferred over the OEM nodular iron...
I got a new steel flywheel for my McLeod...
Can you re-surface the stock flywheel? Yeah, but it's a real budget solution.
