Manual Transmission FAQ - Look Here First!
Old Oct 29, 2008 | 02:21 PM
  #61
71chevytruck's Avatar
Originally Posted by Six Speeds Inc.
Anyone that needs help with something is encouraged to post up. I am more than happy to help you with your questions. Just remember on the weekends it takes me a little longer since Joe hogs the computer
Amber
Please post your questions in a regular thread if it is unique to you. Let's keep this a FAQ Thread. Thanks!
how old of a t56 will bolt to my new engine? I have an 07 6.0 in a 71 c10 and I am looking to convert to t56, do I need anything special? wiring, computer, I am really a noob when it comes to tranny swaps.
Old Feb 11, 2009 | 02:30 PM
  #62
airforcemanss's Avatar
Default no one hastried to respond to my problem hopefully ill be help here
car is a 00 m6 ss 58.xxx miles. i was driving on base friday night going about 15mph in second go to put it in 3rd then the whole car jumped forward but i quickly through it in neutral. bucking an some kind of flexing was felt in the shifter.i go to put it in second now after that and some bucking and flexing happened again because i didn't raise the rpms enough before i shifted to second ( i think) seems like i have a lot of flexing and bucking happens when i shift(i think it's because i don't give it enough gas coming outta the hole when im doing a lot of stop and go). well , next thing you know i go to hit the gas and all this grinding an bad sounds happened and i felt it in the clutch. the clutch wasn't grabbing so i pretty much think i blew my pressure plate on my stock clutch. my buddy in the passenger seat said he's never seen a clutch go like that and i thought the same thing.wtf? has anybody seen or been through this?is this normal? he said maybe because of the cold weather but the car was already warm when it happened?
well now i know where my tax money is going
been doing some reading and it seems the ls7 clutch kit suites me best. the car is bone stock except for the new tick master adj and pro 5.0 shift that went in recently.
What should i replace now that i need a new clutch? a pilot bearing , 01-02 gm slave,ls7 clutch kit anything else while everything is dropped? i hope you guys can give me some helpful info. sorry for the write up
Old Mar 18, 2009 | 07:54 PM
  #63
Tainted 2002WS.6's Avatar
why when shifting into 6th gear it almost sounds lik its grinding just driving normally and when driving hard it makes the same noise going into second sometimes?
Old Mar 19, 2009 | 10:54 AM
  #64
slowpoke96z28's Avatar
sounds like synchros are almost worn down. somebody else on here managed to wear out 6th's synchro. how, idk, but he did.
Old May 5, 2009 | 11:16 PM
  #65
ryans01z28's Avatar
need some help heres where i am https://ls1tech.com/forums/manual-tr...ugestions.html
Old Jul 6, 2009 | 02:53 PM
  #66
Chesty for President's Avatar
Unhappy T56 REBUILD Close to Dallas Fort Worth area
Mine keeps getting stuck in 4th and 3rd is grinding bad. Does anyone have any advice on where to send or take it for a rebuild in the area or within a few hundred miles.....thanks much for any replies or advice
Old Jul 23, 2009 | 05:43 PM
  #67
Project_Reaper's Avatar
Ok so from what ive read through these 4 pages is that the stock 02 LS1 M6 should be good ( depending on your driving style) to around 400-420 HP to the flywheel? am i right? i have the stock M6 in mine with a Moser 9in w/ 3.89 gears and 340HP ( i know...but im working on it) to the wheels, which should be around 390-400 to the flywheel...so i should be good for now right? or should i start concidering tranny upgrades befor my cam and heads?......
Old Aug 5, 2009 | 03:19 PM
  #68
...anyone know what Flywheel HP and TQ rating i can reach befor i should start concidering trans upgrades?
Old Aug 7, 2009 | 05:21 AM
  #69
Tbennett13's Avatar
I recently had a new 6speed installed in my car. everytime I get it a little gas it feels like the trans lifts up. when this happends I can watch my whole center console and shifter ****, along with everything else attatched to the tranny moves up. then as soon as I let off the gas it litteraly slams down or bounces and makes a uncomfortable thud.
any ideas?
Old Aug 7, 2009 | 07:46 AM
  #70
2002 SS HUGG's Avatar
Plus one for REAPER"S question about hp and trq ratings before doing upgraded forks and other T56 internals. Any kind of guesstimation would be appreciated.
Old Aug 21, 2009 | 10:15 PM
  #71
i recon they dont check this one very often lol, if i find out SS ill let ya know
Old Sep 27, 2009 | 06:25 PM
  #72
Noyzee's Avatar
8 second mod
any easy way to bleed a c5 clutch/hydrolic set up?
looked, searched and having a hard time.
thanks
Old Dec 26, 2009 | 07:21 AM
  #73
00 black ss's Avatar
What type of clutch fluid do I need and how much fluid do I need to buy? Imdoing a monster clutch swap and now just need the fluid
Old Dec 27, 2009 | 09:57 AM
  #74
blkdkz28's Avatar
buy one of those big cans of DOT 3. get the cheap stuff its all the same.
BTW you can start a new thread....
Old Feb 21, 2010 | 07:36 PM
  #75
Blown02Camaro's Avatar
So for a stock t56, what can it handle safely and not break? and what does a rebuild run for this transmission?
Old Feb 21, 2010 | 10:09 PM
  #76
SScooter's Avatar
Ok I just put in a fresh T56 in my 99' SS new slave new master and a new centerforce dual friction clutch kit. It shifts nice if you are driving it normal but if I try a 6k rpm shift and clutch it to shift it wont go into the next gear and sometimes the clutch takes a few seconds to actually disengage. My pedal is really low and hits the floor. Wat is my problem?
Old Feb 22, 2010 | 08:12 AM
  #77
Talking
Generally depending on how many miles are on the trans and how rough you drive it, a stock T56 will handle roughly 500HP and 500TQ to the trans its self, which with a %12 drivetrain loss addes up to around 450 @ the wheels, i dont know the exact price range but Viper has the parts to upgrade your T56 to the power level your lookin for from 500-1000+HP. hopefully someone eles can give us a price quote cuz im interested in some viper internals myself
Old Feb 22, 2010 | 08:52 AM
  #78
the_merv's Avatar
Veteran: Air Force
I re-built my own when it was stock..I destroyed my 2nd Gear and a few other things so I bought the Tick Stage II Kit and put it all together. I have about $850 in the rebuild.
Old Feb 22, 2010 | 08:06 PM
  #79
Ok so with about 75000 with a 125/150 shot will be pushing it? And where do you get the viper rebuild kit?
Old Feb 22, 2010 | 11:41 PM
  #80
the_merv's Avatar
Veteran: Air Force
I didn't use a Viper Kit..check out Tick and you will see what I used.
A rebuild would probably help with your plans.
