trany wont go back in?...help!!!
I am putting in a new clutch in a 98 camaro and cant get the tranny to go into the pilot bearing it will go into the disc fine but I CAN NOT get it into the pilot bearing this is the 2nd day trying any tips helpfull info please that tranny is kicking my ***!
p.s. its not the slave cyl holding me.
re
yes I used the tool,slave is still unhooked, and I split tranny and bell the bell is on the motor and the tranny is about a inch&a half from the bell. and the throwout is still a half inch from the diaphram.
Took me and my dad and a neighbor about 3 hours to get it to go on all the way. All we did was take turns under the car rocking the tranny up and down, left and right, all the while pushing the T56 towards the motor. (That thing gets heavy after 15 minutes of rocking.)
LS1Tech Sponsor
The clutch is not aligned perfectly with the pilot bearing.Those plastic alignment tools get you somewhat close but it has to be perfect.Ever since I switched to a real input shaft the tranny's slide in like butter.Before it was a fight.
So,loosen the clutch and realign the clutch assembly.Visual inspect that the tool is centered and it slides in/out very easilly.
use a little bit of upward pressure on the alignment tool when bolting the PP down. you will notice the clutch, with the platic tool, has quite a bit of play in it. it's got to be centered in order for the clutch to slide in easily. if you get it centered good the transmission should slide in very easily. usually takes me about 5 minutes to actually slide the transmission in.
