Skipping gears?
Also when on highway lets say does it hurt transmission to drop from 6th to 3rd? Just checking. My tranny is on way to T56rebuilds right now, but when driving as it was when I would go form 6th, would grind when going down to 3rd/4th. Wasn't as bad going up but did grind sometimes.
As for down shifting, you can overwork the syncro by trying to get intop a lower gear at high speed & low RPM. Thus a grind is the result. You can rev match that helps a ton.
edit-doesn't your sig read A4?
