Z06 clutch
Old Jun 27, 2002 | 01:11 PM
2000blackZ28's Avatar
Default Z06 clutch
What is the best clutch set up to by. I have a 2000 Z and have only taken it to the track once. I guess just from my regular hard driving (1st to 2nd scratches) I wore it out. It drives but I can't launch or make high rpm shifts. I have heard some different opinions on this subject. Will the Z06 clutch assy and flywheel along with the new master and slave hold up to a moderately modified LS1 or do I need to go aftermarket? I've heard some of the aftermarket clutches are hard to break but don't engage very well. Any comments would be helpful.
Old Jun 27, 2002 | 09:26 PM
The Emperor Of Darkness's Avatar
Default Re: Z06 clutch
well I have the kartek clutch and I am very pleased with it. it's expensive but feels like the stock clutch and holds real good. I wouldn't go with ZO6 unless you are not modifying your car.
Old Jun 28, 2002 | 02:17 PM
RTCamaroSS's Avatar
I have the Z06 clutch in my 99 SS. When i replaced the stocker (at 30k miles), i put a new slave in, but kept the stock master. As you can see from my sig, i have quite a few bolt on mods and headers and such. And so far, i have had no problems with slipping or shifting. It launched great every time, even with 315 drag radials.. Im putting nitrous on the car soon, and im going to upgrade the clutch soon after to a spec or a centerforce DF... Gunna need the extra "hold"...
<img border="0" alt="[Camaro]" title="" src="graemlins/camaro.gif" />
Old Jun 28, 2002 | 03:54 PM
Billy C's Avatar
The ZO6 clutch kit with the updated slave is a great bargin ... Unless you race it at the track alot or run spray/H/C , It should hold up fine to a mild bolt on car !!!
Old Jun 28, 2002 | 09:49 PM
SSINFUL's Avatar
If you wore out the stock '00 clutch, the Z06 clutch probably won't go much further (mileage-wise). The *only* thing on the clutch itself that is updated is the pressure plate. Everything else is as it has been since '98.
I installed one last year. Didn't last long, although my car had more hp than the clutch was rated at.
Old Jun 29, 2002 | 12:41 AM
Is the clutch the only thing you replaced? What flywheel, master and slave did you use?
Old Jun 29, 2002 | 06:43 AM
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by 2000blackZ28:
<strong>Is the clutch the only thing you replaced? What flywheel, master and slave did you use?</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">slave is stock, master and pressure plate came along with the clutch....
http://www.cartek.net/
go to cartek clutch and check it out
<small>[ June 29, 2002, 06:47 AM: Message edited by: The Emperor Of Darkness ]</small>
Old Jul 2, 2002 | 10:26 PM
RAMBIRD2002's Avatar
Do yourself a favor and dont waste your time or money. The z06 clutch is a big piece of #@*&. Get a spec or a cartek unit. Speaking from experience.
Old Jul 2, 2002 | 11:00 PM
R U A LS1's Avatar
how come no mention about McCleod? I dont know much about clutches, are these reccommended?
Old Jul 3, 2002 | 07:10 AM
Viper's Avatar
After 2 stockers, a Z06 clutch ( 12K out of it, 330hp ), I finally went with an iron sintered RAM clutch. Don't bother with the Z06; it just puts off the inevitable.
Old Jul 3, 2002 | 06:03 PM
WeatherGuy's Avatar
I improperly posted earlier that I had broken a McLeod twin. The car went up on the rack today, and it turned out to be a broken (carbon fiber) driveshaft. It fooled a bunch of us, since it did not make any noise and acted like a broken clutch at the track.
