whining sound starting to get louder (ls1joe rebuilt it)
well a while ago my transmission was rebuilt by Joe.
all new everything besides the gears
used some amsoil atf in it for a while then went to syncromesh
and a whine is getting louder, and the sound i had in it before has all ways been their after the rebuild.
quick things to check or what should i do
not the best help but i was running synchromesh in my t56 after having it rebuilt by Joe and Amber @t56rebuilds (rebuild is great, Joe and Amber are the greatest) and they said to run Mobil 1 ATF. sorry i couldnt be more help.
i believe that you will be getting noise from the bronze fork pads breaking in, this is what they told me as well. this noise should go away or soften after some time, i would guess after about 3-500 miles. how many miles do you have on your new trans?
Give us a call. Some whining is normal but it should not get louder. It could be the pilot bearing. The best thing to do is call us and tell us what exactly what it is doing. It is possible that it is something else making the noise like the rear but no really way to tell. If it never went away it is possible that it was not the tranny but it is also possible that whatever was making the noise we did not think needed replacing.
If you can give me a call on my cell today. 832-488-0533 and let me know what all it sounds like.
Thanks,
Amber
Thanks,
Amber
Kleeborp the Moderator™
After looking extensively at the different oils available, I think Mobil 1 is the better choice of the two. I just put some in my rebuilt trans today (courtesy of T-56 rebuilds), and it is quieter than it was with the Specialty Formulations MTF Glide that was in there (which was a bit thicker, but still fully synthetic). And while you're at it, swap back to a rubber trans mount for a little bit and see if it helps...it is a pretty quick swap. Mine doesn't make ridiculous noise, though, and I run poly motor AND tranny mounts.
