My t-56 is toast
Old 02-02-2007, 12:58 AM
LSGunZ28's Avatar
Default My t-56 is toast
heres a list ( In order) of how it went bad
grinding into 3rd at high RPMS
grinding into 3rd upshift or downshift no matter what RPM
occasionally getting stuck in 4th ( especially if Im in 4th and decelerate with it still in 4th to a speed lower than 40 mph or so)
Not going into almost any gear at all and if I get it in It is remaining stuck
3rd and 4th are useless. Today I had to drive using 1st, 2nd, 5th and 6th.. and gradualy I felt like I was losing 5th... then 6th....
I dont eeven wanna drive it anymore because I cant!!
Old 02-02-2007, 05:53 AM
oakleyman's Avatar
Dude doesnt sound like a major problem to me! Your saying 3 and 4 are grinding...... From what you just said sound like it could just be the syncro. because 3 and 4 are on the same one which could cause your grinding and not allowing it to dissengage/ engage. I could be wrong man but just trying to help. Sounds like a rebuild could be done no problem! G/L though man!
GO COLTS!!!!!!!
Old 02-02-2007, 12:15 PM
LSGunZ28's Avatar
Yeah, but just a synchro.... What about it getting stuck in all those other gears?
Old 02-02-2007, 02:52 PM
pushinfreight's Avatar
you are just going to have to get that cracked open to see what the problem is.
Old 02-03-2007, 12:53 AM
Phlip00WS6's Avatar
Yea, just pull it apart. Youll find out exactly whats wrong with it then.
Old 02-03-2007, 03:36 PM
LSGunZ28's Avatar
Im gonna order synchros and a couple of other parts regardless of what is wrong, then Ill order the rest, maybe.... Damn! this sucks!
Old 02-03-2007, 08:49 PM
1BADAIR's Avatar
broken 3-4 keys
Old 02-03-2007, 09:31 PM
LSGunZ28's Avatar
I bet, but probably broken anything else now that it isnt shifting into 5th or 6th without getting stuck??
Old 02-04-2007, 01:00 AM
Phlip00WS6's Avatar
Get the basic rebuild kit, steet 3-4 synchro, and some billet keys. Then if you need anything else after opening it up just order it.
Old 02-05-2007, 07:02 PM
LSGunZ28's Avatar
Now I have to drive other cars, I cant drive the Z28!! I hate driving around with a v6 mustang 5 spd!!!
Old 02-06-2007, 05:02 PM
LSGunZ28's Avatar
Im just gonna order the overhaul kit first, then when I take it apart I will order whatever is broken...
Old 02-06-2007, 05:13 PM
PowerShift408's Avatar
You won't be too bad off. While you're in their, upgrade some other little things as well. Mine is down right now courtesy of the T56, but give T56rebuilds a call, tell them what's wrong, and they'll get ya what you need. They're the best.
Good luck with the rebuild!
