LS7 Experience; Good or Bad?
I'm a little confused on what you are saying here. I'm assuming that all these passes were made on a LS7 clutch kit? With the 6200 dump it slipped but with the 4500 and 5000 dumps it did not slip? So are you happy with the kit at your power level (notice my sig) and what type times did you hit on those high 1.6 low 1.7s? Just curious because I'm ordering my kit tomorrow and I don't want to make a mistake if I can help it.
Thanks
im looking to add a 150 shot and i dont think the ls7 will hold that, if i knew what i was gonna do, i would have went with the trexidaila. but yes i am happy with my ls7 clutch
It later went 7.01 @ 103 with a 1.7 60'
These are the same parts I used. However I upgraded to ARP bolts for the flywheel and clutch, plus I decided to go with a lightweight Fidanza flywheel to offset the extra weight.
The LS7+Fidanza= 4-5lbs lighter than stock, so it feels like it always did.
I got my setup from Scoggin Dickey. Great company to deal with!!!
And you like the way it runs with the Fidanza?
J.
As far as being DD friendly, I honestly can't tell a big difference in the pedal from the stock clutch. After bleeding it twice it feels just like stock except holds a ton better. I also performed the "Clutch Test" and had no issues with engagement. High RPM shifts seem to be fine .
The pedal is pretty low however but based off what I've read so is everyone else's unless they have an adjustable Master which I don't. It pedal appears to have raised off the floor between an 1" or so since the install.
Overall Results = Very Happy with the Clutch kit and upgraded Slave!
