View Poll Results: LS7 experience, Good or Bad?
Good
129
90.85%
Bad
13
9.15%
Voters: 142. You may not vote on this poll
LS7 Experience; Good or Bad?
Old May 5, 2009 | 10:25 PM
  #61
slayerized6's Avatar
just ordered my ls7 clutch yesterday. hopefully getting it installed next month!
Old May 6, 2009 | 04:55 PM
  #62
BIG_MIKE2005's Avatar
Mine has been in my car for about 4yrs now & 3 of those years holding up to my current H/C combo. I daily drive it & beat on it every chance I get. It still doesn't slip & just recently my 130k mile stock master just started to stick at high RPM shifts.
I forsee a Monster clutch & Tick master/remote bleeder upgrade in my future.
Old May 7, 2009 | 02:37 PM
  #63
Skeet Skeet's Avatar
Mine let loose at the track last night and I think that I glazed it over. I tried to let it out at 4500 and the pedal stuck to the floor and all I could smell after that was burnt clutch it suck. Now it chatters when I take off. Do you guys think that I need a new clutch?
Old May 7, 2009 | 10:41 PM
  #64
danbo313's Avatar
I'm due for a new clutch in my Z28. I am not as concerned with track passes and longetivity. I drive about 25k+ a year and don't wanna be buy a new clutch once a year.
I have my concerns about putting in another clutch with a self adjusting pressure plate like the stock one. My pedal likes to stick after holding it down for a few seconds now, I don't even have to power shift anymore for it to stick. I have a tilton master cylinder and a newer slave. I am worried the ls7 will start to do the same after a while.
Should I go with the LS7 or get something like a monster Stage 3???
Originally Posted by SladeX
Update to my LS7 clutch
It's been 50k miles now, 200+ drag launches at the track, god knows how many stop and go, many downshifts, burnouts etc
Pedal is releasing high now indicating end of life or near it, BUT its still holding. The winter tires (225) on it are getting roasted by the clutch on launch still and more than half throttle off idle launch. I'll have my spring rims (245) on it in another few weeks, but I suspect the clutch will still have more holding power than the tires. Once the 315's are on, will be a toss up if the clutch decides to slip or not.
Old May 8, 2009 | 11:33 AM
  #65
If your clutch pedal is sticking it isn't the LS7 clutches fault. It's in your hydrolics. You need a better master cylinder.
Old May 10, 2009 | 10:43 AM
  #66
danbo313's Avatar
I've got a tilton 76-1000 master cylinder that I installed in December. I doubt that the master is causing it. My slave was put in last summer too. I'm using a -4 AN line to connect the two.
Old May 11, 2009 | 06:35 AM
  #67
The only problem I have seen causing a sticking pedal is a master not up to the demands, bad slave or combo of both. Just b/c you put in a new master doesn't mean it's doin the job. It's something in your hydrolics otherwise you wouldn't be having pedal stick issues.
Old May 11, 2009 | 01:28 PM
  #68
danbo313's Avatar
I don't have the LS7 clutch, just thinking about getting one.. Don't want anyone thinking i am having problems with the LS7.
Old May 11, 2009 | 06:24 PM
  #69
bearcatt's Avatar
Set up properly there is no better clutch for a daily driver than the LS7... period.
Old May 12, 2009 | 07:59 AM
  #70
oh, ok. Well then it's definetly in your hydrolics then. I would just get a Tick master & never look back. It's made to handle the demands of these cars like no other master I have seen yet.
Old May 13, 2009 | 07:28 AM
  #71
Bader-X's Avatar
light clutch pedal and smooth engagement and no chatter.
a happy user
98 Z28 m6 convertion 224 cam about 360 rwhp
Old May 21, 2009 | 04:28 AM
  #72
Cold Zero's Avatar
Good day ,
As an advise from a member here (Moonder)
change and Master/Sleve Cylinder even if you have 2001/2002
change the Pilot Bearings .. buy ARP bolts for flywheel and pressure plate ..
Byunspeed is a good place to buy the LS7 clutch with cylinders , bearings and ARP bolts
free shipping ! ..
Old Jun 4, 2009 | 12:01 AM
  #73
frankmarroquin's Avatar
I Love it.... Very well priced too.
Old Jun 5, 2009 | 02:08 PM
  #74
Pulse_GTO's Avatar
The LS7 is fine if you are making a few more ponies than stock, but if you are above 350 rwhp, I would look into something more performance oriented.
Old Jun 5, 2009 | 02:12 PM
  #75
bearcatt's Avatar
I think most will agree that the LS7 clutch is definetly good for a lot more than 350rwhp.
450rwhp is about the limit on the LS7 clutches. As a street driven daily driver there is no better clutch.
Drag racing on the otherhand is a completely different story allthough some do it anyways.
Old Jun 5, 2009 | 03:47 PM
  #76
Pulse_GTO's Avatar
Originally Posted by bearcatt
What's the confusion?
For a mild daily driver it is great. Anything above 400 rwhp when driven aggressively it dies.
Old Jun 5, 2009 | 04:46 PM
  #77
00SS6spd's Avatar
I can attest to that. I had an LS7 clutch in my car. LS6 intake, PRC 5.3 heads, Vindicator cam, 9" with 4.11's... The thing didn't like power, it wasn't too long before it started to cook on motor even from a rolling start. And it REALLY didn't like sticky tires.
I went to a Textralia OZ700 Z-grip and haven't had any issues since.
Old Jun 5, 2009 | 04:47 PM
  #78
SKI's Avatar
SKI
What?I cut 1.6-1.7 on a stock clutch in a 98 no less......I am sure the ls7 clutch is rated 550+ ...
Old Jun 5, 2009 | 04:57 PM
  #79
00SS6spd's Avatar
Hey, I didn't design the thing. I'm just telling you what happened to it... And it didn't like sticky tires, or nitrous, or even my car on motor after a few good launches.
Old Jun 5, 2009 | 06:32 PM
  #80
bearcatt's Avatar
Experience and past posts by others in this thread will prove otherwise. That's what the confusion is about.
