How to test for loose Flywheel??
but i was wondering if there is a way to test if the flywheel is loose. i remember hearing somewhere that you can rev the car and shut it off real quick and if theres a loud clunk or noise the flywheel is loose. Dont flame me if thats complete BS, i just remember hearing it somewhere.
Any help, or opinions would be greatly appreciated!
-Derek
I worked great for about a year and then the clutch started engaging closer and closer to the floor. Eventually I could not get the car into gear with the clutch pedal all the way on the floor. I tried replacing the master, and that did not help. Eventually I took my tranny down and started to replace my clutch. When I got to the Pressure plate to flywheel bolts several were finger loose!!!!! Needless to say, the shop had not tightened the PP bolts enough. I will never let a shop work on my car again. I used Red Loctite on the PP bolts when I put it back together.
I don't know what would happen with loose flywheel to crank bolts, but I would think that the clutch would not be disengaging properly if they were loose.
No previous warning.....just a sound from under the car like I'd run over a sack full of aluminium cans / machine gun firing.
The stray bolt took out the bell housing and starter motor.
