Wich slave cylinder to buy.
Old 02-25-2007 | 05:07 PM
LS1crazy01's Avatar
Default Wich slave cylinder to buy.
Hey guys im having the same problem alot of m6 guys seem to be having and that is that on real fast shifts at high rpm my clutch pedal sticks to the floor but if I pump it, it comes up again. I think its the slave cylinder from the info ive been finding on searches. My question is wich slave cylinder to buy? The Ram or the GM one. There like only 10$ apart But wich one will hold up better cause I dont wanna go through this again. Thanks in advance.
Old 02-25-2007 | 06:11 PM
LS1crazy01's Avatar
anybody?
Old 02-26-2007 | 12:23 AM
99huggercamaro's Avatar
ttt... ill be installin it.
Old 02-26-2007 | 04:16 AM
93camaro_zzz's Avatar
It shouldnt be your slave. Really. I had the exact same problem, and the problem is your clutch. Especially if you have stock clutch. If you have a nice aftermarket one, then I would look into your master cylinder. I have an LS7 clutch, and an 02 slave, and it just recently started doing it again to me (minimally) and found out my master was on its way out. So I got a McLeod. Good luck though.
Old 02-26-2007 | 07:47 PM
LS1crazy01's Avatar
It only happens during real hard accleration not all the time. Well anyway I orderd the Ram and I'll see how it goes I guess.
Old 02-26-2007 | 07:56 PM
Nasty99SS's Avatar
have the same problem but mine doesnt come back up for a while......but my slave cylinder was leaking so I ordered 01 gm slave cylinder from texas speed peformance and a mcleod adjustable master cylinder
Old 02-26-2007 | 08:46 PM
LS1crazy01's Avatar
Yah if this dont work then Im gonna order the master cylinder as well.
Old 03-03-2007 | 06:24 PM
Freddyrdzls1's Avatar
more than sure its your master cylinder.. a mcleod would be the perfect one to have... anyone with an ls1- 6speed wants a mcleod...
thats the highest weakest thing on an ls1.. the master...expands and pressure is lost at high revolutions of the clutch...trust me get a mcleod........
Old 03-03-2007 | 08:37 PM
sidewayz28's Avatar
this was the same as my case.. since its obvious a stocker cant really hold 400+rwhp ill be order a new clutch/fly wheel/ adjustable master cylinder/& slave cylinder
