my McLeod SFI bellhousing install
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
Well I have the bolts that came with it. I also cant keep it up there inless I put a couple of bolts in it to hold it. I dont know where the problem is with the starter, I put it up there and theres toom all the way aroud it? Is the problem with the motor plate or the bellhouseing it self? I can see where the plate could be close but it sets up there fine.
Mine went in pretty fairly easy for the most part. I didn't use any of the motor plate/bellhousing bolts either. Here's a couple links to other installs if you already haven't seen them.
https://ls1tech.com/forums/manual-transmission/258875-mcleod-sfi-bellhousing-installed-pics-info-within.html
http://www.fastlsx.com/forums/showthread.php?t=9515
well I got it in today, not to bad. Better than I thought it would be. I used a spare inout shaft to aline my twin disk. Finally got it so it would slid in and out easy
The only problem I had was the bolt just above the starter pulled out the threads
I never even torqued down on it? I have everyother one tight and its all comeing apart at the end of the season if it last that long
and at that time I'll be useing a different block so I think it should be ok for now. Thanks for the help guys.
![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
![Bang Head](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_banghead.gif)
![Driving](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_driving3.gif)
![Cheers!!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_cheers.gif)
well i found something pretty interesting today. since i've had the car back together i have not been able to power shift it & the clutch has been "catching" about 3" off the floor.
today i got it on the lift and checked the distance/clearance between the TO bearing & pressure plate. amber told me it should be around .050" well mine is a LOT more then that! by like a 1/4". i know of one other guy with the same problem.
i'm gonna get a custom spacer made like the SPEC one and that should fix my problem.
