Z06 Clutch Parts, Drill Mod Questions!
I went ahead with everything mentioned on this page. I kept the stock master and did the drill mod.
I used installuniversity.com with "Buschman's Clutch Bleed Method" (do a search on this board). Everything worked right off the bat.
Getting the #$@$#R!@#$$#%# clutch master cylinder out of the car was more of a pain the yanking the transmission. I tried following the directions on installuniversity.com, but ended up having to loosen the brake booster to barely get the clutch stuff out. And be carefull not to pull the clutch pedal too far backward or you will pop the tension spring out!
See ya...
See ya...
