LUK clutch????? is it worth it????
i have a clutch specialist down here in houston and he has a clutch shop and all he puts in is luk. is this a good replacement clutch, i may trade my TA in for an 02 but if i keep mine is that a good clutch to put in even if i decide to do a little performance>
Unless you're going for more than 450 rwhp... use an LS7 clutch. They've got a lot of grip and a lot of life, and they won't hurt your pocket too bad. SDPC has the Clutch/PP/Flywheel kit for $399.
Originally Posted by winger4800
I'm thinking about the LUK Pro GOLD kit that comes with Aluminum flywheel.....
LUK is the OEM clutch GM uses..... the "LS7" clutch is made by LUK I believe....My LS6 clutch was....
