looking for the disconnect tool for slave cylinder
looking for the disconnect tool for slave cylinder that connects the braided line to the slave cylinder. does anyone have one or where could i get it???
thanks
thanks
I can sell you two screwdrivers taped together with "Clutch Line Tool" written across it....
Only $59.99 while supplies last, so hurry!
J/K Just do what the above poster said.
i only use one screwdriver, but im pimp like that.. lol
just push the ring in, go around pushing it, while pushing the hose in some (to take the tension off) then when the ring is completely in, pull the line off.
once you do it one time, you'll see how it works, and be able to do it easily from then on.
Originally Posted by MrDude_1
not reemoving that... we're talking about the line on the red capped connection in your pic
Originally Posted by 5w20
i know, look at the end of that where the little black dot is. Theres a pin in there that you can hit out with a punch so you don't have to mess with the other connection.
I mean, you can pull the heads to change the spark plugs, but that might not be the best method...
Originally Posted by studderin
they really make a tool for this?
as far as the roll pin thing.. sure, thats great.. IF you somehow pull the transmission with the line connected..
think about it.
and yes, i know how to tap out the roll pin... i also know how to swap that line to a straight -3AN line.. theres a good thread on that in the conversion/hybrid section...
actually they do make a tool for takin the quik connect loose form the slave (i tried one from advance one time came in a stock ls1 clutch kit, they let me have the tool) but it sucks and I bent mine first try. use a small screwdriver it takes 2 seconds
