DOT 5 fluid for your clutch???
i know that DOT 5 fluids are, due to thier silicone base, inherently compressilbe (even if mildly). knowing that, would it be okay to use as clutch fluid?? the only reason i ask is because it has a higher boiling point than the DOT 4 that GM recommends so maybe i wouldnt have the flush my cluth hydraulics so often.
I would just use Valvoline SynPower Synthetic DOT 3/4 brake fluid in the clutch system. Its compatible with both DOT 3 and DOT 4, and its synthetic so its less resistant to heat and breakdown, so it should last much longer than conventional fluid.
DOT 5 = no no. You could use DOT 5.1 though, which is compatible with DOT 3/4 fluids.
Personally, I use Castrol SRF. High dry boiling point, really high wet boiling point. Not sure if it will eat seals or not, but someone has to try it and find out...
Originally Posted by dailydriver
IF I were a rich man...this is what I would use (in the brakes as well)!
Originally Posted by PureWS6
Doesn't GM Make "clutch fluid"? I have heard it is expensive though.
Its less than $8 a can from the dealer.
Originally Posted by xBROKEx
is there a dot3/4 with a really high boiling point since we seem to have issues with fluid boiling in the lines
Is there a reason why more people don't use this?
Does anyone know what the boiling point is of the gm brake fluid?
Originally Posted by shoemike
i doubt it, i have the mcleod master cylinder and the instructions
said not to use DOT5 in the system.
Werd. I just got a mcleod street twiin and the master cylinder. The instructions say clearly do not use the 5. It says the 3 has more lubricity.
