Which Clutch for Nitrous and Cam???
Old Jun 2, 2003 | 09:51 PM
LS1FenixBird99's Avatar
Default Which Clutch for Nitrous and Cam???
Im going to get a 100 wet shot and an aftermarket cam. I dont know which odf each yet, but i want to get a new clutch first, because mine is a stocker with 43k on it. I was lookin at a spec III, but i was wondeing if i should just get the clutch or if i need the rest, like flywheel, and all that stuff.
Old Jun 3, 2003 | 09:40 AM
99MONGOOSE's Avatar
Default Re: Which Clutch for Nitrous and Cam???
Do yourself a BIG favor and go with RAM. RAM stands behind their products better then anyone. The clutch kit is a little pricey but you get what you pay for in the car world. You would need the 910 clutch disk designed to work with nitrous. If I were you I would get the RAM 910/402 VDS clutch kit. The kit would include:
-billet steel flywheel(the disk will chew up your OEM flywheel).
-clutch 910 disk
-402 pressure plate
-throw out bearing
-adjustable master cylinder(new) You absolutely need to have an adjustable master.
-new slave cylinder
Contact Rapid Motorsports, Mikey will hook you up!
Old Jun 3, 2003 | 11:45 AM
Viper's Avatar
I'll throw this out for what it's worth.
I use the RAM 980 disk, and kept the stock flywheel. The 980 is iron sintered one side, organic for the flywheel side.
6K miles later, it is fine.
What would be the sign to know if you're flywheel is being chewed up?
Old Jun 3, 2003 | 12:20 PM
xaon's Avatar
i went with the SPEC Stage 3 carbon on mine with their Gen2 pressure plate, resurfaced flywheel, and stock 2001 hydraulics.
It's been in for about 6,000 miles and has held up to quite a few 6,000rpm dumps spraying a 100shot out of the hole on ET Drags.
With your car being a 99 model, you've got to upgrade hydraulics anyways, I would probably go with the entire Ram VDS kit if I were in your position.
Old Jun 3, 2003 | 03:58 PM
99MONGOOSE's Avatar
Viper the 910 disk doesn't have the organic side. The 980 is designed to work with the oem flywheel
Old Jun 3, 2003 | 04:03 PM
Viper's Avatar
Cool, thanks. Hey, as soon as winter leaves Cleveland I need to head out to Mentor to check out your car.
Old Jun 3, 2003 | 08:50 PM
14u2nv's Avatar
aka 99mongoose
Hell yeah come on out! I am always looking for sweet cars. You just might want to join the SCORPION RACING club too!
Old Jun 3, 2003 | 09:20 PM
Assassin's Avatar
what about mcleod twin disc?
Old Jun 3, 2003 | 10:37 PM
Why do you say that i would need to redo the hydraulics???
Old Jun 4, 2003 | 02:58 PM
99MONGOOSE's Avatar
2001-up have a better updated salve then 98-99 and you NEED an adjustable master.
Old Jun 4, 2003 | 06:20 PM
theblur98ss's Avatar
Get the mcloed twin disk and be done with it. You never know what the future will bring. I did a spec stage 4 last year and now I'm wishing I would have went with the twin. No problems with the spec but it's only rated at 700hp and I hope to surpass that.
Old Jun 4, 2003 | 06:48 PM
Yea, i dont think im gonna be goin more then 700. Ill just keep it in the 4's. Thanx for the info. man, this is gonna cost more then i thought...
